> It runs !!!!! mickey mouse engineering prevails :), Mallory Dizzy AND D-Jet working together
Mueller
post Jan 22 2005, 08:55 PM
914 Freak!
Background:
For the stock D-Jet, the ECU gets the signal to fire the injectors from a set of mechanical breaker points inside the base of the distributor. There is nothing wrong with the factory method except for the fact that if you want to run the D-Jet injection, you have to keep the factory distributor...not anymore (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I have successfully been able to electronicly trigger the ECU from a pair of optical sensors inside of the billet Mallory distributor....so far I have only put a few miles onto the car with this setup and I don't know how it'll work when the temperature is much higher (currently it is 45° outside.....)
it's ugly right now, but give me some time to clean it up... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-2-1106100569.jpg)
So for my ignition, I have the Mallory distributor, accel coil and new 8.5mm plug wires....starts right up and idles fine, but I might install a CDI box anyways...
lapuwali
post Jan 24 2005, 11:19 AM
Not another one!
QUOTE (KenH @ Jan 24 2005, 08:46 AM)
Some time ago - sombody indicated there was an optimum relationship, depending on driving conditions. I will try and find the info.
Another way to do it might be to "trigger" an IC "divide by 2" off the points and feed that to the ECU. Hummm
Ken
If there is an "optimum relationship" between timing of valve events and timing of injection events, it's mostly theoretical, and will only be effective at light loads and low revs.
L-Jet works very well, and doesn't time injection events with spark events. It only uses the distributor input to determine engine speed. K-Jet also works very well, and it's injecting 100% of the time. No timing of injection to engine events at all.
True "sequential injection", which times injection events to valve events, can help a small amount near idle for smoother idle quality. It also has some effect on reducing idle emissions. If you hunt up the DIY EFI email archives, or go over to the MS EFI board, you'll find the details. The short answer is that the injectors are open for so much of the cycle at higher loads that timing them simply makes no difference.
Mueller   It runs !!!!! mickey mouse engineering prevails :)   Jan 22 2005, 08:55 PM
xsboost90   i love it..dont need it but i love it anyways!   Jan 22 2005, 08:58 PM
r_towle   Will this be a kit, or will you be selling the diz...   Jan 22 2005, 09:06 PM
nebreitling   VERY nice job mueller -- this idea was a long time...   Jan 22 2005, 09:10 PM
SirAndy   schweet dude! http://www...   Jan 22 2005, 10:11 PM
Brett W   Is that ...... http://ww...   Jan 22 2005, 10:14 PM
Mueller   no, that is not JB Weld http://www....   Jan 22 2005, 10:33 PM
Brett W   Whew, I feel so much better.   Jan 22 2005, 10:36 PM
McMark   Make one that fits in the stock distributor and in...   Jan 23 2005, 02:53 AM
DJsRepS   Nice work there Mueller! Keep us posted how it...   Jan 23 2005, 09:14 AM
DJsRepS   I hope you don't go Colonel Saunders on us and...   Jan 23 2005, 09:20 AM
lapuwali     Jan 23 2005, 10:37 AM
Mueller   <...   Jan 23 2005, 10:58 AM
SpecialK   <...   Jan 23 2005, 02:22 PM
rick 918-S   Good job mike! http://www.9...   Jan 23 2005, 03:13 PM
KenH   Mike, What timing relationship did you keep betwe...   Jan 23 2005, 03:54 PM
Mueller     Jan 23 2005, 04:22 PM
Mueller   I was just looking at the stock trigger points.......   Jan 23 2005, 04:45 PM
KenH   Some time ago - sombody indicated there was an opt...   Jan 24 2005, 10:46 AM
lapuwali     Jan 24 2005, 11:19 AM
Mark Henry   Very cool Mike http://www.914...   Jan 24 2005, 11:37 AM
Mueller     Jan 24 2005, 12:01 PM
bondo   You say mickey mouse engineering.. are those optic...   Jan 24 2005, 12:39 PM
Mueller     Jan 24 2005, 12:46 PM
Jeff Bowlsby   You're a creative guy Mike, but is this a solu...   Jan 24 2005, 02:29 PM
Mueller   <...   Jan 24 2005, 02:49 PM
balthazar   I wouldn't call it mickey mouse engineering...   Jan 24 2005, 03:31 PM
rick 918-S   Hey Mike, How about a cheap LSD or a way to modify...   Jan 24 2005, 04:06 PM
drgchapman   Mike, I'm lurking in the background awaiting f...   Jan 24 2005, 04:08 PM
fiid   http://www.914world.com/bbs2/...   Jan 24 2005, 04:23 PM
KenH   GARY, Call Paul - you can buy replacment gears wi...   Jan 24 2005, 08:10 PM
KenH   Opps it was Rick who wanted the LSD info. Ken   Jan 24 2005, 08:36 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:49 PM
