| Bigdamdork |
Aug 24 2023, 05:31 PM
Newbie ![]() Group: Members Posts: 22 Joined: 19-July 23 From: Santa Maria, CA Member No.: 27,476 Region Association: Central California |
Hey Everyone. Based in no small part on the suggestions from my original thread about what order to do my restore I picked up some steel and pushed my Makita metal cut-off saw the limit. I'm ready to start putting this together. My question is I have a Weldpack 3200. I bought it a couple of years ago just to play with things. Some metal art, built a Santa Maria Style BBQ, etc. Per the instructions, the metal is .125 (so close to 11 gauge?) for the 2x4's. Am I fooling myself by thinking I could use this welder to put the jig together? The welder says it can handle 12ga to 1/4" with .035 gasless flux cored wire DC(-). I just don't know enough about the duty cycle, etc. to know if I should just suck it up and buy a bigger welder. I figure once I get into the car I should be fine as it's mostly 18ga sheet metal so I hate to buy one just for the jig but will if I need to I guess. Maybe find a buddy with one. Just wanted to get some expert's thoughts as my total welding time is about 2 hours. I plan on being an expert post-rebuild. (IMG:style_emoticons/default/unsure.gif)
Super appreciate any advice you can offer. Thank You!! ![]() ![]() [attachmentid=885729] ![]() Attached image(s)
| mb911 |
Aug 25 2023, 04:31 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,730 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Ok one last tidbit. So there is this negative thought on self shielded flux core (they make a gas shield version). Self shield flux core is used extensively in iron working on the west coast so almost every commercial building you see in California, Arizona, Nevada, etc is built using a self shielded flux core almost identical to what your running in your little 110 welders (common type NR211)
Bigdamdork Welding Question Aug 24 2023, 05:31 PM
jhynesrockmtn Try it or test on a similar gauge metal. If the w... Aug 24 2023, 06:49 PM
Superhawk996 It will work
I just used a whimpy 120v welder to... Aug 24 2023, 08:40 PM
flat4guy I have helped a friend build 3 cars using this sam... Aug 24 2023, 08:45 PM
targa72e I think the important part is you are not making a... Aug 24 2023, 09:50 PM
MikeK With that 110V welder, I’d consider tapering the... Aug 25 2023, 01:42 AM
mb911 Ok I hate these threads only because 99.9% of the ... Aug 25 2023, 05:47 AM
Superhawk996 @mb911
Curious about the duty cycle. His machi... Aug 25 2023, 06:43 AM
mb911
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 25 2023, 07:19 AM
76-914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 25 2023, 06:22 PM
Shivers
I’m using the same welder. I built this contr... Aug 25 2023, 06:58 AM
mlindner And then if you are using an extension cord, keep ... Aug 25 2023, 08:53 AM
Superhawk996
And then if you are using an extension cord, keep... Aug 25 2023, 11:42 AM
930cabman Try it and keep your eye on overheating the machin... Aug 25 2023, 09:11 AM
Jack Standz Not an expert here, but you'll probably be hap... Aug 25 2023, 11:42 AM
Superhawk996
. . .(they make a gas shield version).
Do tel... Aug 25 2023, 11:33 PM
mb911
[quote name='mb911' post='3098005' date='Aug 25 2... Aug 26 2023, 05:29 AM
Superhawk996
[quote name='mb911' post='3098005' date='Aug 25 ... Aug 26 2023, 06:55 AM
Jack Standz Yes, choose the right process for the project and ... Aug 25 2023, 04:47 PM
willieg A welder, working on an exterior staircase, told m... Aug 26 2023, 08:30 AM
mb911
A welder, working on an exterior staircase, told ... Aug 26 2023, 09:42 AM
Front yard mechanic Hard to beat an old school stick welder for tube a... Aug 26 2023, 09:57 AM
targa72e I think this topic diverged a lot. There is a ton ... Aug 26 2023, 10:43 PM
MikeK
I think this topic diverged a lot. There is a ton... Aug 27 2023, 08:24 AM
Shivers https://www.nexair.com/learning-center/you-...of%2... Aug 27 2023, 09:17 AM
Bigdamdork Just wanted to say "THANK YOU" for the i... Aug 30 2023, 03:33 PM
Superhawk996 Speaking only for myself - I’m no expert. I get... Aug 30 2023, 04:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:39 PM |
