> Welding Question, Welding
Bigdamdork
post Aug 24 2023, 05:31 PM
Hey Everyone. Based in no small part on the suggestions from my original thread about what order to do my restore I picked up some steel and pushed my Makita metal cut-off saw the limit. I'm ready to start putting this together. My question is I have a Weldpack 3200. I bought it a couple of years ago just to play with things. Some metal art, built a Santa Maria Style BBQ, etc. Per the instructions, the metal is .125 (so close to 11 gauge?) for the 2x4's. Am I fooling myself by thinking I could use this welder to put the jig together? The welder says it can handle 12ga to 1/4" with .035 gasless flux cored wire DC(-). I just don't know enough about the duty cycle, etc. to know if I should just suck it up and buy a bigger welder. I figure once I get into the car I should be fine as it's mostly 18ga sheet metal so I hate to buy one just for the jig but will if I need to I guess. Maybe find a buddy with one. Just wanted to get some expert's thoughts as my total welding time is about 2 hours. I plan on being an expert post-rebuild. (IMG:style_emoticons/default/unsure.gif)
Super appreciate any advice you can offer. Thank You!!
Attached Image Attached ImageAttached ImageAttached Image[attachmentid=885
729]Attached Image
mb911
post Aug 25 2023, 04:31 PM
Ok one last tidbit. So there is this negative thought on self shielded flux core (they make a gas shield version). Self shield flux core is used extensively in iron working on the west coast so almost every commercial building you see in California, Arizona, Nevada, etc is built using a self shielded flux core almost identical to what your running in your little 110 welders (common type NR211)
Superhawk996
post Aug 25 2023, 11:33 PM
QUOTE(mb911 @ Aug 25 2023, 06:31 PM) *
. . .(they make a gas shield version).
Do tell - not aware of something different than common flux core.
When you say they make a gas shield version - are you referring to solid wire used with typical shielding gas or are you saying there is a self shielding version that doesn’t leave usual flux core kind of slag and spatter?
I apologize if I’m misunderstanding the post. Would love some thing self shielding for outside use but less messy than NR-211 type flux core wire.
@mb911
mb911
post Aug 26 2023, 05:29 AM
QUOTE(Superhawk996 @ Aug 25 2023, 09:33 PM) *
@mb911
Gas shielded flux core is very common in manufacturing. It is still a tubular wire (hollow) with flux and then they use typically co2 or a 75/25 mix. Often referred to dual shield. AWS numbers of E71-T or similar. It is meant for heavy plate welding and favors spray transfer mode.
Superhawk996
post Aug 26 2023, 06:55 AM
QUOTE(mb911 @ Aug 26 2023, 07:29 AM) *
@mb911
Always learn something new from you (IMG:style_emoticons/default/aktion035.gif)
Bigdamdork   Welding Question   Aug 24 2023, 05:31 PM
jhynesrockmtn   Try it or test on a similar gauge metal. If the w...   Aug 24 2023, 06:49 PM
Superhawk996   It will work I just used a whimpy 120v welder to...   Aug 24 2023, 08:40 PM
flat4guy   I have helped a friend build 3 cars using this sam...   Aug 24 2023, 08:45 PM
targa72e   I think the important part is you are not making a...   Aug 24 2023, 09:50 PM
MikeK   With that 110V welder, I’d consider tapering the...   Aug 25 2023, 01:42 AM
mb911   Ok I hate these threads only because 99.9% of the ...   Aug 25 2023, 05:47 AM
Superhawk996   @mb911 Curious about the duty cycle. His machi...   Aug 25 2023, 06:43 AM
mb911   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 25 2023, 07:19 AM
76-914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 25 2023, 06:22 PM
Shivers   I’m using the same welder. I built this contr...   Aug 25 2023, 06:58 AM
mlindner   And then if you are using an extension cord, keep ...   Aug 25 2023, 08:53 AM
Superhawk996   And then if you are using an extension cord, keep...   Aug 25 2023, 11:42 AM
930cabman   Try it and keep your eye on overheating the machin...   Aug 25 2023, 09:11 AM
Jack Standz   Not an expert here, but you'll probably be hap...   Aug 25 2023, 11:42 AM
mb911   Ok one last tidbit. So there is this negative thou...   Aug 25 2023, 04:31 PM
Superhawk996   . . .(they make a gas shield version). Do tel...   Aug 25 2023, 11:33 PM
mb911   [quote name='mb911' post='3098005' date='Aug 25 2...   Aug 26 2023, 05:29 AM
Superhawk996   [quote name='mb911' post='3098005' date='Aug 25 ...   Aug 26 2023, 06:55 AM
Jack Standz   Yes, choose the right process for the project and ...   Aug 25 2023, 04:47 PM
willieg   A welder, working on an exterior staircase, told m...   Aug 26 2023, 08:30 AM
mb911   A welder, working on an exterior staircase, told ...   Aug 26 2023, 09:42 AM
Front yard mechanic   Hard to beat an old school stick welder for tube a...   Aug 26 2023, 09:57 AM
targa72e   I think this topic diverged a lot. There is a ton ...   Aug 26 2023, 10:43 PM
MikeK   I think this topic diverged a lot. There is a ton...   Aug 27 2023, 08:24 AM
Shivers   https://www.nexair.com/learning-center/you-...of%2...   Aug 27 2023, 09:17 AM
Bigdamdork   Just wanted to say "THANK YOU" for the i...   Aug 30 2023, 03:33 PM
Superhawk996   Speaking only for myself - I’m no expert. I get...   Aug 30 2023, 04:08 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:42 PM
