> Welding Question, Welding
Bigdamdork
post Aug 24 2023, 05:31 PM
Hey Everyone. Based in no small part on the suggestions from my original thread about what order to do my restore I picked up some steel and pushed my Makita metal cut-off saw the limit. I'm ready to start putting this together. My question is I have a Weldpack 3200. I bought it a couple of years ago just to play with things. Some metal art, built a Santa Maria Style BBQ, etc. Per the instructions, the metal is .125 (so close to 11 gauge?) for the 2x4's. Am I fooling myself by thinking I could use this welder to put the jig together? The welder says it can handle 12ga to 1/4" with .035 gasless flux cored wire DC(-). I just don't know enough about the duty cycle, etc. to know if I should just suck it up and buy a bigger welder. I figure once I get into the car I should be fine as it's mostly 18ga sheet metal so I hate to buy one just for the jig but will if I need to I guess. Maybe find a buddy with one. Just wanted to get some expert's thoughts as my total welding time is about 2 hours. I plan on being an expert post-rebuild. (IMG:style_emoticons/default/unsure.gif)
Super appreciate any advice you can offer. Thank You!!
Attached Image Attached ImageAttached ImageAttached Image[attachmentid=885
729]Attached Image
willieg
post Aug 26 2023, 08:30 AM
A welder, working on an exterior staircase, told me code required gas shielded flux core for commercial metal stairways. This is on the West Coast. Also I agree with @mb911 comments on duty cycle. 20% duty cycle at 100 Amps means 2 minutes of welding in a 10 minute period. Most people aren’t going to be welding for that long a time in a 10 minute period.
Bigdamdork   Welding Question   Aug 24 2023, 05:31 PM
jhynesrockmtn   Try it or test on a similar gauge metal. If the w...   Aug 24 2023, 06:49 PM
Superhawk996   It will work I just used a whimpy 120v welder to...   Aug 24 2023, 08:40 PM
flat4guy   I have helped a friend build 3 cars using this sam...   Aug 24 2023, 08:45 PM
targa72e   I think the important part is you are not making a...   Aug 24 2023, 09:50 PM
MikeK   With that 110V welder, I’d consider tapering the...   Aug 25 2023, 01:42 AM
mb911   Ok I hate these threads only because 99.9% of the ...   Aug 25 2023, 05:47 AM
Superhawk996   @mb911 Curious about the duty cycle. His machi...   Aug 25 2023, 06:43 AM
mb911   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 25 2023, 07:19 AM
76-914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Aug 25 2023, 06:22 PM
Shivers   I’m using the same welder. I built this contr...   Aug 25 2023, 06:58 AM
mlindner   And then if you are using an extension cord, keep ...   Aug 25 2023, 08:53 AM
Superhawk996   And then if you are using an extension cord, keep...   Aug 25 2023, 11:42 AM
930cabman   Try it and keep your eye on overheating the machin...   Aug 25 2023, 09:11 AM
Jack Standz   Not an expert here, but you'll probably be hap...   Aug 25 2023, 11:42 AM
mb911   Ok one last tidbit. So there is this negative thou...   Aug 25 2023, 04:31 PM
Superhawk996   . . .(they make a gas shield version). Do tel...   Aug 25 2023, 11:33 PM
mb911   [quote name='mb911' post='3098005' date='Aug 25 2...   Aug 26 2023, 05:29 AM
Superhawk996   [quote name='mb911' post='3098005' date='Aug 25 ...   Aug 26 2023, 06:55 AM
Jack Standz   Yes, choose the right process for the project and ...   Aug 25 2023, 04:47 PM
willieg   A welder, working on an exterior staircase, told m...   Aug 26 2023, 08:30 AM
mb911   A welder, working on an exterior staircase, told ...   Aug 26 2023, 09:42 AM
Front yard mechanic   Hard to beat an old school stick welder for tube a...   Aug 26 2023, 09:57 AM
targa72e   I think this topic diverged a lot. There is a ton ...   Aug 26 2023, 10:43 PM
MikeK   I think this topic diverged a lot. There is a ton...   Aug 27 2023, 08:24 AM
Shivers   https://www.nexair.com/learning-center/you-...of%2...   Aug 27 2023, 09:17 AM
Bigdamdork   Just wanted to say "THANK YOU" for the i...   Aug 30 2023, 03:33 PM
Superhawk996   Speaking only for myself - I’m no expert. I get...   Aug 30 2023, 04:08 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:43 PM
