> Front Suspension, Do or Delay
DennisV
post Aug 26 2023, 03:23 PM
How critical is it to replace the bushings and related from suspension components on a car that has sat indoors for 20 years? Is the worst case the handling a little sloppy? Or am I looking at high risk for being stranded or in an accident?
I have been working to get our 1970 914-6 back on the road. Safely and reliably of course.
I have very limited windows to work on the car. It is in another state. So to avoid this becoming a never ending project, I have tried not to slide into a full restoration. I have focused on:
  • Engine rebuild
  • Transmission rebuild
  • Brake system replacement
  • Fuel system replacement
I have access to a lift where the car currently is, and the brakes are off. So I'm real tempted to do the front suspension now. That said, if everything went great that will add another few months before the car would hit the road due to the distance and how frequently I get access to the car.
barefoot
post Aug 27 2023, 11:01 AM
By all means replace at least the rear bushing in the front a-arms. That will have sagged to the point that the torsion bar is rubbing on the ID of the arm, loosing paint protection thus leading to corrosion and torsion bar fracture. The front bushing bears much less static load so they don't sag.
It happened to me, came out one morning & the car sat low in front on one side. Pulled the bar out and it had fractured starting at a corrosion pit. Back then new bars were pretty cheap, not so much now. Slight corrosion can be buffed out & re-coated, saving the bar.
Now get to work & have some fun (IMG:style_emoticons/default/beer.gif)
DennisV
post Aug 27 2023, 06:22 PM
QUOTE(barefoot @ Aug 27 2023, 10:01 AM) *
Thanks for sharing. Had not read about this. Are you referring to #22 in the parts catalog?
While in this section, I see a note that front stabilizer is 73-. Is that correct? No front stabilizer on 914-6? Ours currently has one. I assume that since I removed the rear I should remove the front as well. If removed, what goes in its place? Is there a plug for the mount?
DennisV   Front Suspension   Aug 26 2023, 03:23 PM
technicalninja   If I was some distance from the car I'd take i...   Aug 26 2023, 03:47 PM
DennisV   I'd be more worried about wheel bearings, bal...   Aug 27 2023, 06:00 PM
mlindner   Like Rick said, pull it off and take home. The pro...   Aug 26 2023, 06:13 PM
windforfun   "Tires are another thing that I don't tru...   Aug 26 2023, 06:39 PM
rjames   "Tires are another thing that I don't tr...   Aug 26 2023, 09:54 PM
Jamie   "Tires are another thing that I don't t...   Aug 27 2023, 09:02 AM
vitamin914   "Tires are another thing that I don't tr...   Sep 7 2023, 06:42 AM
technicalninja   "Tires are another thing that I don't tr...   Aug 26 2023, 07:13 PM
windforfun   Thanks for the interesting reply. I appreciate yo...   Aug 26 2023, 07:47 PM
worn   Thanks for the interesting reply. I appreciate y...   Aug 26 2023, 08:08 PM
technicalninja   I too, hate the current crop of tire monkeys... I...   Aug 26 2023, 08:38 PM
BillJ   Edited as Not constructive. Glad you are getting ...   Aug 27 2023, 10:32 AM
barefoot   By all means replace at least the rear bushing in ...   Aug 27 2023, 11:01 AM
DennisV   By all means replace at least the rear bushing in...   Aug 27 2023, 06:22 PM
barefoot   [quote name='barefoot' post='3098335' date='Aug 2...   Aug 28 2023, 07:08 AM
Shivers   [quote name='barefoot' post='3098335' date='Aug 2...   Aug 29 2023, 02:20 PM
DennisV   Nooooooo. Leave the front on and what was the mat...   Aug 31 2023, 06:42 PM
rhodyguy   Is #22 the foam disc that goes on the torsion rod?...   Aug 27 2023, 07:47 PM
technicalninja   [quote name='barefoot' post='3098335' date='Aug 2...   Aug 27 2023, 08:22 PM
burton73   This is what a bunch of front end parts look like ...   Aug 28 2023, 02:33 PM
Al Meredith   Dennis, Does your rack and pinion come from a 914 ...   Aug 28 2023, 03:45 PM
burton73   Dennis, Does your rack and pinion come from a 914...   Aug 28 2023, 04:22 PM
DennisV   Dennis, Does your rack and pinion come from a 914...   Aug 31 2023, 06:40 PM
DennisV   Dennis, Does your rack and pinion come from a 914...   Sep 6 2023, 04:26 PM
burton73   [quote name='Al Meredith' post='3098583' date='Au...   Sep 6 2023, 04:40 PM
iankarr   Um. Is the logic here..."I'm still alive,...   Aug 29 2023, 11:31 AM
Mikey914   There are several versions of the racks. We have f...   Sep 6 2023, 10:03 PM
Mikey914   There are a few oddballs, but technically they are...   Sep 6 2023, 10:06 PM
technicalninja   My landlord has a 2012 Bentley. His wife got it fo...   Sep 7 2023, 08:02 AM
rhodyguy   The cost to refurb a rack is eye opening. Not argu...   Sep 7 2023, 12:21 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:12 AM
