| Stef914 |
Aug 29 2023, 04:30 PM
human ![]() ![]() Group: Members Posts: 117 Joined: 21-July 21 From: Los Angeles Member No.: 25,745 Region Association: Southern California |
Hi there,
Interested to hear your thoughts on dropping the engine. It appears that removing the heat exchangers can be quite challenging. So, if that happens to be the situation, what's your procedure for dropping the engine with the heat exchangers still attached to the motor? Any recommendations, tips, suggestions, or workarounds would be appreciated (IMG:style_emoticons/default/wink.gif) I understand that handling the heat exchangers can get tricky when the muffler is detached… Thanks in advance! |
| falcor75 |
Aug 29 2023, 11:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
Taking the HE off isnt the hard part, getting them to seal up against the heads again without overtorquing the nuts and pulling out a HE stud is the tricky bit.
Stef914 Dropping Engine Aug 29 2023, 04:30 PM
brant More likely to damage the heads and f you don’t ... Aug 29 2023, 04:38 PM
Robarabian If you leave the muffler and bracing attached, you... Aug 29 2023, 04:51 PM
emerygt350 I took the muffler off, rested the engine mount on... Aug 29 2023, 06:43 PM
johnhora Why are you dropping your engine? Aug 29 2023, 06:47 PM
bkrantz It can be done, with some increased bulk to deal w... Aug 29 2023, 07:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 06:46 PM |
