Carb throat balance when tuning now a rebuild saga !, those with Zenith carbs can learn from my bad fortune ? |
porschetub |
Aug 29 2023, 11:25 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Doing a tune on my Zeniths ,cant find an exact rpm range and done a ton of research ;
Bruce Anderson mentioned 1800 in his book, Factory says 1000 in the gary.suggate site factory manual, Haynes manual tells us 1000. So far I have tuned throats @ idle ,1000rpm ,1400 and 1800 on hand throttle and strangely I get the same balance any way ?. Now thinking its not an issue but would appreciate feedback from 6yl guys with carbs,TIA,cheers |
nditiz1 |
Aug 30 2023, 09:18 AM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
It's not an issue to tune them at idle. You want to make sure they are close. If 1 is bouncing between 5.25 and 5.75 your middle ground is 5.5 make sure the other 6 are around there too. If one is bouncing around 5.3 and 5.8, that's close enough.
The main think is getting the linkage set once they are all relatively balanced. Checking at different RPMs to ensure both open and close as one through the range. Also, you want to make sure you are getting to WOT. So many carbs have be tuned without ever checking and people wonder why their car is under powered. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:24 PM |
