> It runs !!!!! mickey mouse engineering prevails :), Mallory Dizzy AND D-Jet working together
Mueller
post Jan 22 2005, 08:55 PM
914 Freak!
Background:
For the stock D-Jet, the ECU gets the signal to fire the injectors from a set of mechanical breaker points inside the base of the distributor. There is nothing wrong with the factory method except for the fact that if you want to run the D-Jet injection, you have to keep the factory distributor...not anymore (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I have successfully been able to electronicly trigger the ECU from a pair of optical sensors inside of the billet Mallory distributor....so far I have only put a few miles onto the car with this setup and I don't know how it'll work when the temperature is much higher (currently it is 45° outside.....)
it's ugly right now, but give me some time to clean it up... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-2-1106100569.jpg)
So for my ignition, I have the Mallory distributor, accel coil and new 8.5mm plug wires....starts right up and idles fine, but I might install a CDI box anyways...
Mueller
post Jan 24 2005, 02:49 PM
914 Freak!
QUOTE (bowlsby @ Jan 24 2005, 01:29 PM)
You're a creative guy Mike, but is this a solution without a problem? Stock dizzys work fine, replacements are available...
So why the need for this other than its new?
some people would like a newer or more modern distributor???
at least for our region PCA, the ignition is free to upgrade, yet the FI must remain stock....with the Mallory and MSD distributors, they can be tailored with different features such as non-stock advance curves. The new distributors also have larger diameter caps and rotors which in theory should help reduce spark scatter with more powerful/aggressive ignitions..
I can also now run a CDI box that should just be plug-n-play.
The original engine wiring harness plugs right up...the new ignition can be removed and replaced with the original with no signs of tampering...so your wiring harness will work perfect (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
granted, most people that want or need a better ignition will have carbs or an aftermarket FI, this was done mostly to prove an idea I had and due to me wanting to run the Mallory ignition setup while retaining my D-jet (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I can tell you the car does start and idle better, but I'm sure it's mostly due to me getting rid of the points and going with an electronic ignition.....
Mueller   It runs !!!!! mickey mouse engineering prevails :)   Jan 22 2005, 08:55 PM
xsboost90   i love it..dont need it but i love it anyways!   Jan 22 2005, 08:58 PM
r_towle   Will this be a kit, or will you be selling the diz...   Jan 22 2005, 09:06 PM
nebreitling   VERY nice job mueller -- this idea was a long time...   Jan 22 2005, 09:10 PM
SirAndy   schweet dude! http://www...   Jan 22 2005, 10:11 PM
Brett W   Is that ...... http://ww...   Jan 22 2005, 10:14 PM
Mueller   no, that is not JB Weld http://www....   Jan 22 2005, 10:33 PM
Brett W   Whew, I feel so much better.   Jan 22 2005, 10:36 PM
McMark   Make one that fits in the stock distributor and in...   Jan 23 2005, 02:53 AM
DJsRepS   Nice work there Mueller! Keep us posted how it...   Jan 23 2005, 09:14 AM
DJsRepS   I hope you don't go Colonel Saunders on us and...   Jan 23 2005, 09:20 AM
lapuwali     Jan 23 2005, 10:37 AM
Mueller   <...   Jan 23 2005, 10:58 AM
SpecialK   <...   Jan 23 2005, 02:22 PM
rick 918-S   Good job mike! http://www.9...   Jan 23 2005, 03:13 PM
KenH   Mike, What timing relationship did you keep betwe...   Jan 23 2005, 03:54 PM
Mueller     Jan 23 2005, 04:22 PM
Mueller   I was just looking at the stock trigger points.......   Jan 23 2005, 04:45 PM
KenH   Some time ago - sombody indicated there was an opt...   Jan 24 2005, 10:46 AM
lapuwali     Jan 24 2005, 11:19 AM
Mark Henry   Very cool Mike http://www.914...   Jan 24 2005, 11:37 AM
Mueller     Jan 24 2005, 12:01 PM
bondo   You say mickey mouse engineering.. are those optic...   Jan 24 2005, 12:39 PM
Mueller     Jan 24 2005, 12:46 PM
Jeff Bowlsby   You're a creative guy Mike, but is this a solu...   Jan 24 2005, 02:29 PM
Mueller   <...   Jan 24 2005, 02:49 PM
balthazar   I wouldn't call it mickey mouse engineering...   Jan 24 2005, 03:31 PM
rick 918-S   Hey Mike, How about a cheap LSD or a way to modify...   Jan 24 2005, 04:06 PM
drgchapman   Mike, I'm lurking in the background awaiting f...   Jan 24 2005, 04:08 PM
fiid   http://www.914world.com/bbs2/...   Jan 24 2005, 04:23 PM
KenH   GARY, Call Paul - you can buy replacment gears wi...   Jan 24 2005, 08:10 PM
KenH   Opps it was Rick who wanted the LSD info. Ken   Jan 24 2005, 08:36 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:49 PM
