Carb throat balance when tuning now a rebuild saga !, those with Zenith carbs can learn from my bad fortune ? |
porschetub |
Aug 29 2023, 11:25 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Doing a tune on my Zeniths ,cant find an exact rpm range and done a ton of research ;
Bruce Anderson mentioned 1800 in his book, Factory says 1000 in the gary.suggate site factory manual, Haynes manual tells us 1000. So far I have tuned throats @ idle ,1000rpm ,1400 and 1800 on hand throttle and strangely I get the same balance any way ?. Now thinking its not an issue but would appreciate feedback from 6yl guys with carbs,TIA,cheers |
porschetub |
Sep 3 2023, 05:51 PM
Thanks for all the replies and sorry for the delay, I can get them very close but critical to have idle screws even for normal idle and upping engine speed for balancing .
Spent a lot of time dialing the length of the drop links and have replaced many worn out ball cups ,strangely nearly all RH thread ones were worn out ? . When I first rebuilt these before I fitted the 2.2T motor I noticed both side cam rollers had seized @ some stage and there were area's on the rollers that had flat spotted and there was a lot of wear on the throttle cams which I have since replaced. Both the carbs were in very poor condition,I had no history when I bought this engine but the seller on behalf of the owner did say that "it ran like shit" this turned out to be a blessing as I knocked the price down and it turned out just to be the carbs and I had bought a strong engine. Working on more carb repairs as our crap fuel has buggered several parts just waiting to hear back from alfa 1750 on ebay,will update ,cheers. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:27 PM |
