Dual EMPI 44HPMX Tuning, What am I doing wrong? |
UkonCornelious |
Sep 4 2023, 02:27 PM
Newbie Group: Members Posts: 16 Joined: 10-February 21 From: Richmond, VA Member No.: 25,192 Region Association: Middle East |
I have recently gotten everything needed to get my car back on the road after 15 years of sitting. I have a newly rebuilt, street cam 2056 with dual 44HPMX EMPIs and I am trying to get it running better.
The engine sounds pretty solid when operating between 3-5k, but below that (and at idle) it doesn't sound great. There are lots of exhaust pops and the engine seems to sputter a little while cruising at constant speed. I understand that you typically set the idle speed and then turn each idle screw in until the engine slows/ starts to die. Then you turn it out slowly until the engine runs smooth again. The problem is that the driver side carb doesn't seem to react at all when I screw either of the idle screws in all the way, and then backed out to 5 full rotations (which is the limit supposedly according to the video I watched). Do I have the wrong size idle jets? Are 44s just too big for this motor? Do I have an intake leak? Is the timing off somehow? (I originally set the timing with a light at break in) What do you think I should check or measure to get my carbs tuned properly? |
UkonCornelious |
Sep 4 2023, 07:13 PM
Thanks, rfinegan for the advice and information. I'll take a look at the jet pac kit when I get a chance.
Well, I went ahead and tried taking the idle jets out to clean them. There was actually a little debris in BOTH! After cleaning them out and reinstalling in the carb, the car seems to be much happier. The low speed throttle response has greatly improved and there's much less exhaust pops while cruising. I'm still a novice when it comes to tuning dual carbs so any help would be much appreciated. |
Lo-Fi Version | Time is now: 4th June 2024 - 03:37 PM |
