914/6 CV question, Conversion part compatibility |
69911s |
Sep 13 2023, 08:48 AM
Newbie Group: Members Posts: 2 Joined: 17-November 18 From: The Plains, Virginia Member No.: 22,660 Region Association: MidAtlantic Region |
Greetings all and thanks for providing such a valuable resource here. I've been finding most of my answers but I can't find this one. As I noticed that the rear wheel bearing was the same as my front 996 part it occurred to me that other parts might match as well. I tried a 996 CV and sure enough it bolts right up to the 108mm flanges that I plan to use and the Sway-away axle slides right in. Since the 996 had 295 HP from the factory I'm assuming the power won't be an issue so if I can find the right size boots is there any reason not to use them. They are much narrower than the early 108 CVs but attractive because of availability and cost. Thoughts?
DennisV |
Sep 13 2023, 01:33 PM
Member Group: Members Posts: 479 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
so if I can find the right size boots The boots with different part numbers, and even vendors for the same part, have different ID. For example: Stoddard * 901-332-293-10 53 MM * 901-332-293-11 51 MM * 901-332-293-12 56 MM Rein rubber boot part is about 5mm smaller opening (48 mm) on the large end of the boots compared to what I took off our car, despite it being associated with 901-332-293-11 |
Lo-Fi Version | Time is now: 1st June 2024 - 01:10 PM |
