> An Electrical 'distribution block' for extra Switched items ?
Literati914
post Sep 20 2023, 03:49 PM
I'm adding several aux items to the electrical system of my '72.. most of which will be powered thru relays (constant + and switched power). The constant power will be via an extra fuse block that I'm adding over towards the right hand side of the steering column w/ a red power wire directly from the battery.
My question is - can I simply add a single wire from a switched location on the OE fuse block (#9) and run it over to an aftermarket 'distribution block' at the right of the column?
This way I could potentially add several 'switched' relays off of it, as well as just switched/non-relay items.. while not cramming so many extra wires into the stock fuse box. This seems preferable but I can not find an instances of anyone going this route. So in theory it seems logical to me - will this not work ?
https://www.amazon.com/Terminal-Distributio...r=1-15&th=1
Literati914
post Sep 20 2023, 05:28 PM
QUOTE(windforfun @ Sep 20 2023, 05:47 PM) *
Yes, it will work.
Is the hardware SS? I would prefer SS.
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif)
This particular one ^^ is only described as being made of "premium copper". I'll see if there's anything similar in SS tho, thanks.
- Lo-Fi Version Time is now: 19th July 2025 - 11:02 PM
