> New 914 Owner
ogdougy
post May 10 2022, 01:30 PM
Hello all!
Just making a quick introduction. Made my first 914 purchase just about two weeks ago now and now starting to dive into this car.
Its a 73 non-California car with the EB 1.7. 100k ish miles on it with a motor that is leaking like crazy (more on that later). Single 32/36 weber. Classic Auto Air AC unit. Fiberglass GT Flares, Empi Replica Fuchs, and a bunch of shit ripped out of the engine bay. Bout all i know on these
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-26536-1652211032.1.jpg)
Next to my AE86 Track car that is currently getting a cage welded in
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-26536-1652211033.2.jpg)
So now getting to the real stuff. I have worked on boxers before, i have an 400 HP ej22 on e85 in my Forester (that needs to get pulled, RIP transmission). But I have never worked on an air cooled one.
Right now, i have been doing some basic maintenance that i do when i get a car. Change all fluids, been changing all the hoses on the motor because they look like the original ones, added a catch can, etc....
But of course after changing the oil and pressure washing the bottom on the engine/trans. I notice this thing is pissing oil out the rear main. So i decided with the unknown state of the motor, im just going to do a rebuild.
Reading around its seems like the easiest thing is to buy a AApistons 19XX cc or 20XX cc kit. I dont have a horsepower goal in mind. I just want this rebuild and hopefully get close to the same mpgs i had with the 1.7 (30 mpgs on the highway driving between Phoenix and Tucson)
The end goal with this motor. I have an entire pertronix flamethrower vacuum dist with the correct coil and plugs. While the 32/36 works for now. I will replace them with 40 IDF webers. Then some new headers and exhaust. The horsepower I get is what I get. Not too big of a concern.
Q1: With my motor being a 1.7 i have to get the heads machined to fit the larger cylinders and some massaging of the combustion chambers to get the the compression down. Correct?
Q2: Cam choice. Do people run the original 1.7 cam or just get a "street/oem" grind from Web.
This was a long one but I look forward to what i can learn!
ogdougy
post May 21 2023, 07:52 PM
QUOTE(DRPHIL914 @ May 15 2023, 05:13 AM) *
very nice and welcome - late welcome i just saw your thread today not sure how i missed its beginning,
nice clean fast work wow!!! it’ll be back on the road in no time at all! at first i thought maybe since you had a suby motor you might go that direction but it’s nice to see you using the original case and completing a more original but performance air cooled car.
Phil
The suby motor may make it's way into this car. But for once in my life I wanted to enjoy a car in its stock(ish) form lol.
And the work continues!!!
Figuring out the PO's wiring mess making new alternator and alternator cables. Even gave the board a little cleaning. Just need to add the ground so the fuel relay will work.
(IMG:https://i.imgur.com/9KGDcJMh.jpg)
(IMG:https://i.imgur.com/mQB5vRGh.jpg)
Putting new transmission side CV joints. All new shift rod bushings are in. PO didnt even have the fire wall bushing in for the shift rod. Also added a relay for the starter.
(IMG:https://i.imgur.com/gsXqipIh.jpg)
I was getting ready to put the other CV join on and noticed a little bit of glisten on the transmission case.
(IMG:https://i.imgur.com/Ts3nzS9h.jpg)
Very hard to see but i think the output shaft is leaking, so good thing I noticed it before putting a nice new greasy CV joint on (IMG:style_emoticons/default/smile.gif). Once thats all done i have new clutch and speedo cable going on. Just want to get everything on so i can start fabing up my exhaust.
(IMG:https://i.imgur.com/VI5TtAYh.jpg)
And if you excuse the nasty-ness. Fuel pump routing is done and added new pads for the fuel tank.
(IMG:https://i.imgur.com/kyPv7Awh.jpg)
Porschef
post Sep 21 2023, 11:47 AM
How you doin'
QUOTE(ogdougy @ May 21 2023, 09:52 PM) *
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-12152-1695318456.1.jpg)
Get yourself a Tangerine Racing firewall bushing. Can’t say enough about how much better your shifting will be. (IMG:style_emoticons/default/beerchug.gif)
How much cussing was involved with the discovery of the plug hole issue? (IMG:style_emoticons/default/dry.gif)
ogdougy   New 914 Owner   May 10 2022, 01:30 PM
930cabman   Welcome aboard How is your new 914 currently runn...   May 10 2022, 01:59 PM
ogdougy   Welcome aboard How is your new 914 currently run...   May 10 2022, 07:47 PM
Dave_Darling   If you are not using the stock FI, ditch the cam a...   May 10 2022, 02:28 PM
Costa05   :wttc: Another Arizona 914 owner. Are you in Pho...   May 10 2022, 03:27 PM
808 WRX   Are you sure you don't want to swap in a subar...   May 10 2022, 04:06 PM
ogdougy   Well during the tear down it seems like a bunch of...   May 14 2022, 08:15 PM
bkrantz   Well during the tear down it seems like a bunch o...   May 14 2022, 08:32 PM
porschetub   Well during the tear down it seems like a bunch ...   May 14 2022, 11:16 PM
930cabman   Well during the tear down it seems like a bunch ...   May 16 2022, 04:56 AM
Justinp71   Well during the tear down it seems like a bunch o...   May 14 2022, 11:27 PM
Cairo94507   Welcome to the club. I would just add, if you are...   May 15 2022, 07:09 AM
aharder   :wttc: These are great cars to play with !...   May 15 2022, 09:35 AM
ogdougy   Well I at least found the culprit. Someone was as ...   May 15 2022, 09:33 PM
Shivers   Hey dude, helicoils have a use, It will get you...   May 15 2022, 09:48 PM
ogdougy   Hey dude, helicoils have a use, It will get you ...   May 18 2022, 09:44 AM
ogdougy   I got the motor out and have begun to take it apar...   May 21 2022, 08:16 PM
PanelBilly   I missed saying welcome.   May 21 2022, 09:00 PM
krazykonrad   :wttc: As you can already see, You've come to ...   May 22 2022, 01:58 PM
76-914   :wttc: That's the worst install of a helicoil ...   May 22 2022, 06:13 PM
ogdougy   Well motor is split and the bad stuff keeps on com...   May 26 2022, 03:56 PM
Shivers   The engine came out of a 914. Good news. It is bas...   May 26 2022, 04:25 PM
ClayPerrine   The engine came out of a 914. Good news. It is ba...   May 27 2022, 11:45 AM
Shivers   The engine came out of a 914. Good news. It is b...   May 27 2022, 12:43 PM
MM1   So. . .you’re in deep now . . .as many have said...   May 27 2022, 01:42 PM
ogdougy   As the updates come. I have bought a 2056 stroker ...   Jun 18 2022, 02:32 PM
ogdougy   So, as my parts are coming in I realized i have ma...   Jun 20 2022, 07:56 PM
jim-c   I highly recommend European Motorsports, Hawthorne...   Jun 21 2022, 08:52 AM
burton73   :wttc:   Sep 21 2023, 12:36 PM
krazykonrad   Also, ditch the single carb. If you are not runnin...   Jun 21 2022, 02:51 PM
Dave_Darling   Double-check the registers in the heads where the ...   Jun 22 2022, 10:32 PM
ogdougy   Engine is back together. Had the machine shop remo...   Feb 18 2023, 04:29 PM
rick 918-S   Nice work on that engine. :assimilate: You are a ...   Feb 18 2023, 08:38 PM
ogdougy   Nice work on that engine. :assimilate: You are a...   Feb 25 2023, 08:43 PM
ogdougy   Found the reason why my interior kept getting myst...   Feb 25 2023, 08:50 PM
ClayPerrine   Found the reason why my interior kept getting mys...   Feb 26 2023, 09:22 AM
Puebloswatcop   :wttc: And so the terminal illness begins....   Feb 26 2023, 07:35 AM
malcolm2   Welcome to the world.... and Hey, Register your VI...   Feb 26 2023, 08:30 AM
ogdougy   Final one all done. Just need to get some bondo to...   Mar 5 2023, 05:09 PM
Cairo94507   Before selecting a motor builder, I would vet them...   Mar 6 2023, 09:32 AM
ogdougy   Continuing the clean up. The battery tray is in an...   Mar 20 2023, 11:46 AM
ClayPerrine   Fuel lines are gone as well will be replacing it...   Mar 20 2023, 12:10 PM
ogdougy   Making some progress. Engine bay is as good as it ...   Apr 23 2023, 08:56 PM
ogdougy   Got the correct flywheel finally. Had a lot of per...   May 13 2023, 08:02 PM
Cairo94507   Very nice work; this is obviously not your first r...   May 14 2023, 06:35 AM
Geezer914   Very nice work! Welcome to the club.   May 14 2023, 10:37 AM
DRPHIL914   very nice and welcome - late welcome i just saw yo...   May 15 2023, 06:13 AM
ogdougy   very nice and welcome - late welcome i just saw y...   May 21 2023, 07:52 PM
Porschef   Putting new transmission side CV joints. All ne...   Sep 21 2023, 11:47 AM
r_towle   :wttc: Nice work!   May 21 2023, 09:15 PM
Shivers   Looks great! I added gussets to my brackets...   May 22 2023, 07:09 AM
ogdougy   Output shaft seals came in and in they went. New C...   May 30 2023, 12:27 AM
Cairo94507   Great work. It looks like the mufflers are oval. ...   May 30 2023, 07:44 AM
ogdougy   And we're back. Had one major set-back. My br...   Sep 20 2023, 05:45 PM
930cabman   An option may have been to chase the threads while...   Sep 21 2023, 03:55 PM
ogdougy   An option may have been to chase the threads whil...   Sep 23 2023, 06:44 PM
ogdougy   List of things to come from this weekend: 1. 2 of...   Sep 25 2023, 12:01 PM
Root_Werks   Great progress! Seems like you'll have th...   Sep 25 2023, 12:10 PM
Justinp71   Good job! People will think that has a motorc...   Sep 26 2023, 11:24 AM
Front yard mechanic   Sounds like z1   Sep 26 2023, 04:05 PM
ogdougy   Finally got it driving over the Christmas break. P...   Jan 13 2024, 09:17 PM
- Lo-Fi Version Time is now: 6th July 2025 - 01:28 PM
