will this front suspension work?, what else do i need? |
xsboost90 |
Jan 25 2005, 06:04 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
ok so a friend of mine has a 78 911 and recently switched the front end over to bigger spindles, torsion bars, brakes. He said he would sell me...
-torsion bars -steel calipers -spindles shocks -new rotors-hopefully w/ bearings also has a set of aluminum calipers fairly cheap for same car.... all for under $300. BUT will this all fit on my 76 914/4 and what else do i need. I know there may be some kind of deal w/ the ball joint-anything else. OH and im planning on doing the 930 tie rod ends, is this something i immediatly have to do if i switch front ends? Just for sake of getting it back together-ill switch them before i race or anything. Attached image(s) |
Jeroen |
Jan 25 2005, 08:15 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Like Rich mentioned, you need 911 A-arms to use 911 t-bars
IIRC, the stock 911 t-bars are 19mm, just like the 914, so that won't be an upgrade... All said and done, I think if you need to go shopping for the missing parts (a-arms, hubs, bearings, calipers) you'll be out more expesive than if you just buy a complete 911 front end some place else... |
Lo-Fi Version | Time is now: 9th June 2024 - 10:02 PM |
