> To be double sure of bad alternator
stoneman30hotmail
post Sep 21 2023, 05:58 PM
I read some threads and "how to test alternator regulator". But they're pretty rudamentary. I don't get 13.5 V at the battery, it just stays at almost 12V. So I gather that usually means alternator. I do see 13.5V at the D+ pin and 3-4 at the DF pin. Does that mean the regulator is trying to work? I thought the 13.5 V meant that the alternator was putting 13.5 somewhere. I tried to short these to "full field" the alternator and fried a small wire without change at the battery. The regulator looks original and I would of course rather change that.
Spoke
post Sep 21 2023, 06:26 PM
Jerry
You can try removing the VR and shorting D+ to DF then starting the car. This will cause the alternator to put out maximum voltage. See what you get at the battery. The battery voltage during this test should be north of 15V.
BTW, is the GEN light on during normal operation of your 914?
stoneman30hotmail
post Sep 22 2023, 11:01 AM
QUOTE(Spoke @ Sep 21 2023, 08:26 PM) *
17V with that test. So regulator! The trick was taking off the old regulator I guess. Tryinng to short while running didn't work. (IMG:style_emoticons/default/beer.gif)
Spoke
post Sep 22 2023, 11:07 AM
Jerry
QUOTE(stoneman30hotmail @ Sep 22 2023, 01:01 PM) *
Seems to point to the VR. For sure it's easier to swap a VR versus the alternator....
stoneman30hotmail
post Oct 9 2023, 08:45 AM
QUOTE(Spoke @ Sep 22 2023, 01:07 PM) *
I'm not so sure now. While running I get a nice 13-14V at the battery. But the gen light is still on as there is 17 V at D+. So I'm expecting the alternator to quit.
GregAmy
post Oct 9 2023, 08:53 AM
QUOTE(stoneman30hotmail @ Oct 9 2023, 09:45 AM) *
I'm not so sure now. While running I get a nice 13-14V at the battery..
So the alternator is putting out...
...But the gen light is still on as there is 17 V at D+.
Bad diode in the alternator. That 3-4V differential is enough to turn on the GEN light. Looks like an alternator swap is in your future...sigh...
On the plus side...the D+ 17V is only connected to the GEN light. So if you're willing to tolerate that light for a while (or willing to disconnect and tape off the wire) then it is not hurting anything and you can change the altie at your leisure.
I drove mine like that for some weeks while I got the part (had a core rebuilt by a crusty old dude in NH for $125, killer workmanship) and worked up the motivation for the fidgety job (a friend on top while you're working the bottom helps). - GA
- Lo-Fi Version Time is now: 9th May 2025 - 07:44 PM
