> Best Location for AF Sensor Bung, UPDATE: I got a SS muffler, what you all say now...
913B
post Apr 22 2023, 12:39 AM
I am going Microsquirt. My current muffler right before I tried cleaning the dust off the part label and it just incinerated is a Dansk 1.8 muffler from what the PO said.
I did have to reweld and rotate tip to exit correctly under the valence.
Maybe it was a bus muffler?
Anyone have any experience on where to place the AF sensor bung, too bad its not on the car to check for clearance/obstruction issues.
I was thinking of welding it on the tail pipe where the black circle I marked off.
I could buy a new exhaust with the bung attached, but this is my attempt at going Microsquirt without spending too much and work with what I have.
Anyone cut one up before and know of a good spot?
Thanks in advance.
Ted
913B
post Oct 13 2023, 07:41 PM
I got a new to me muffler.
I believe it was originally purchased from 914rubber.
@Mikey914 @mb911
What do you all recommend for the placement of the AF sensor ??
I am trying to avoid hitting into into any baffles.
Thank you
913B   Best Location for AF Sensor Bung   Apr 22 2023, 12:39 AM
emerygt350   You are going to want it closer to the heat I thin...   Apr 22 2023, 05:35 AM
BeatNavy   I've been running Microsquirt for a couple of ...   Apr 22 2023, 05:35 AM
StarBear   This bung may be my next project - maybe this comi...   Apr 22 2023, 06:19 AM
76-914   Within 12" of the header. If installing on a ...   Apr 22 2023, 08:24 AM
StarBear   Within 12" of the header. If installing on a...   Apr 22 2023, 09:36 AM
technicalninja   WB O2 sensors are heated and can be placed anywher...   Apr 22 2023, 10:10 AM
Superhawk996   One work around might be to lengthen the tip. I d...   Apr 22 2023, 11:37 AM
technicalninja   Superhawk, your car would look great in leopard pr...   Apr 23 2023, 10:32 AM
Superhawk996   Still BIG and expensive! Child’s play. ...   Apr 23 2023, 10:44 AM
914werke   You'll be money ahead replacing that with an d...   Apr 23 2023, 02:28 PM
913B   Dang a Horiba $2999, new Bursch exahaust ...   Apr 23 2023, 04:14 PM
technicalninja   And remember that Horiba is USED! Parts for it...   Apr 23 2023, 04:52 PM
914werke   Dang a new Bursch exahaust $899!! t...   Apr 24 2023, 09:58 AM
pilothyer   Dang a new Bursch exahaust $899!! ...   Sep 12 2023, 04:28 AM
technicalninja   I'd put it in the final collector where the tw...   Sep 12 2023, 06:16 AM
burton73   I'd put it in the final collector where the t...   Sep 12 2023, 06:43 AM
technicalninja   That location is EXCELLENT! You are going to ...   Sep 12 2023, 06:57 AM
VaccaRabite   When I had the Triad exhaust on my car adding the ...   Sep 12 2023, 08:42 AM
JamesM   Best location with your current muffler would prob...   Sep 12 2023, 10:57 AM
913B   I got a new to me muffler. I believe it was origi...   Oct 13 2023, 07:41 PM
technicalninja   I would need to figure out where all primaries cam...   Oct 13 2023, 10:01 PM
mb911   I have absolutely ZERO to do with 914 rubber. That...   Oct 14 2023, 04:23 AM
913B   Reviving my old thread, any member have a clue wh...   Jun 14 2026, 09:52 PM
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: friethmiller
- Lo-Fi Version Time is now: 15th June 2026 - 04:54 AM
