Shift alignment issues, Should have left it alone! |
Petepat |
Oct 23 2023, 06:04 AM
Member Group: Members Posts: 60 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None |
So I have a 1/1/72 1.7L with a slightly sloppy shift (what's new) so I ordered some bushes and dismantled the shift only to find somebody had beaten me to it and it was fine. BUT putting it back with the right alignment is proving difficult, I can get some gears but not others, is there a tip on putting these things back with the correct alignment? Why did I touch it? I note in the Haynes manual I appear to have the later shift, the one with 2 springs which seems odd. Any tips gratefully received.
rhodyguy |
Oct 25 2023, 03:11 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Side, shift linkage enters on the driver side of the trans case. Tail, linkage operates a rod that enters the bottom of the back end of the trans. Photo Post #3. Entire linkage is dif for the SS. As is the dr side warm air guide. See if you can source a Haynes manual. The SS linkage uses 2 set screws. They are typically considered a one time use item. Beware when they back out on their own, near impossible to shift.
Lo-Fi Version | Time is now: 17th June 2024 - 11:27 AM |
