Oversquare Motors Build, (Shorter Stroke, Bigger Piston Build) |
tjtryon |
Oct 26 2023, 10:04 AM
Newbie Group: Members Posts: 20 Joined: 15-June 16 From: Indianapolis Member No.: 20,112 Region Association: None |
Good Morning!
I'm looking at a rebuild of my 1973 2.0 Motor. When I raced motorcycles, I was constantly rebuilding my motors, chasing the speeds I want, and putting the power where I wanted it in my motor RPM. One thing I (and most that I raced with) did was rebuilding with an over-square motor build. The 2.0 914 Type 4 motor has a stock stroke & bore of 94mm (bore-cylinder width) and 71mm (stroke - piston travel). By moving to a shorter stroke, such as 68mm, the piston would move less in the cylinders, which would allow me to run a bigger piston with less stress on the piston (rings move less causing less friction and less heat) allowing me to run a bigger piston, and would move max power higher up in the RPM range, and allow for a higher max RPM. Less movement for the piston would cause less movement on the rods and crank as well. My thoughts are to run 103mm pistons, and a crank of 68mm, allowing for a displacement of a 2.3l (2266 cc). I've been looking into a Falicon forged crank, Carrillo Titanium Rods and JE forged pistons. I think this could allow for a much stronger engine than any other I would have. Does anyone here have any experience with a short stroke, big bore motor? How about those engine builders reading through this? Any thoughts or experiences? |
mepstein |
Oct 26 2023, 11:28 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Heads, cams, induction and exhaust all come into play. Displacement and piston size is just part of the consideration.
tjtryon |
Oct 26 2023, 12:24 PM
Heads, cams, induction and exhaust all come into play. Displacement and piston size is just part of the consideration. Yep, I've already been planning for the entire build. 68mm x 103 mm Falicon Forged Crank ($1500) Carillo Titanium Rods - length based on stroke ($1500) Web Camshafts - https://aapistons.com/products/type-4-porsc...s-1-base-circle - $800 JE Forged Pistons & Liners - $ 2,163.90 - https://aapistons.com/collections/porsche-p...ds-to-be-edited Type 4 Stage 3 DTM Coling Kit (LN Engineering - https://lnengineering.com/type-4-store/dtm-...3-dtm-kit.html) - $1,850.75 AMC Heads 103mm - https://aapistons.com/products/vw-type-4-po...eads-44x36-pair - $ 2,163.90 |
Lo-Fi Version | Time is now: 10th June 2024 - 10:52 AM |
