> Dwell Angle, Timing, and CHT sensor questions, Timing way off (well above 27 Deg) but runs...???
NJ914
post Nov 13 2023, 10:57 AM
Looking for inputs from those who know...
Situation: Engine runs but timing is way off. 27 degrees is at 1800rpm[b]. 3500rpm is in the mid to upper 30's. When attempting to adjust the distributor to spec, engine dies. Only runs at higher timing angle. Not sure what the cause is.
1: Distributor gap is currently at 0.018" and dwell is 50-51 degrees through speed range.
Per the Haynes book, 1 degree of dwell can change the timing by 3 degrees.
Spec is 44 to 50 degrees.
Is this correct?
If I open the gap larger to bring the dwell down to 44 degrees, will this help bring the timing closer to spec?
2: Measured the CHT sensor cold and it was 3100 ohms. I believe it is supposed to be more in the 2000 - 2500 ohm range...?
What is the correct range for the CHT sensor cold?
It is supposed to drop below 100 ohms when up to temp. Is this correct?
Could the higher than spec resistance of the CHT sensor be contributing to the timing issue?
NJ914   Dwell Angle, Timing, and CHT sensor questions   Nov 13 2023, 10:57 AM
StarBear   1. Dwell Looks right on. Sure you have light on th...   Nov 13 2023, 01:24 PM
NJ914   1. Dwell Looks right on. Sure you have light on t...   Nov 13 2023, 01:58 PM
914sgofast2   I suggest taking the dizzy out of the engine and d...   Nov 13 2023, 01:43 PM
NJ914   I suggest taking the dizzy out of the engine and ...   Nov 13 2023, 02:00 PM
StarBear   Here is one of many threads on the CHT temp curve:...   Nov 13 2023, 02:46 PM
NJ914   With some help from @Starbear this past weekend,...   Dec 5 2023, 12:58 PM
Geezer914   Sounds like the cam timing is off. Is this an ori...   Dec 5 2023, 02:42 PM
NJ914   Sounds like the cam timing is off. Is this an or...   Dec 13 2023, 01:22 PM
914_teener   It is not necessary to remove the engine to replac...   Dec 13 2023, 03:07 PM
VaccaRabite   I suspect you have a configuration error. What ar...   Dec 14 2023, 11:21 AM
NJ914   I suspect you have a configuration error. What a...   Dec 18 2023, 02:43 PM
Dave_Darling   See if you can compare the marks on the fan to the...   Dec 14 2023, 07:41 PM
GregAmy   See if you can compare the marks on the fan to th...   Dec 14 2023, 09:24 PM
Superhawk996   See if you can compare the marks on the fan to t...   Dec 14 2023, 09:29 PM
NJ914   See if you can compare the marks on the fan to th...   Dec 18 2023, 02:44 PM
VaccaRabite   See if you can compare the marks on the fan to t...   Dec 18 2023, 03:59 PM
emerygt350   Yeah, verify tdc first but I don't think you a...   Dec 14 2023, 08:04 PM
GregAmy   :agree: Where I was going with this...you have n...   Dec 18 2023, 04:12 PM
NJ914   :agree: Where I was going with this...you have ...   Dec 20 2023, 01:44 PM
Dave_Darling   1: The distributor rotor is pointing toward the #...   Dec 20 2023, 03:00 PM
NJ914   1: The distributor rotor is pointing toward the ...   Jan 2 2024, 03:22 PM
NJ914   [quote name='Dave_Darling' post='3119075' date='D...   Jan 8 2024, 11:49 AM
emerygt350   TPS doesn't even need to be hooked up and the ...   Jan 8 2024, 12:02 PM
NJ914   TPS doesn't even need to be hooked up and the...   Jan 9 2024, 02:21 PM
GregAmy   Yuuuuup. And you're using an adjustable timin...   Dec 20 2023, 02:44 PM
StarBear   Aarghhh. Looking for a great ending!   Jan 8 2024, 04:48 PM
- Lo-Fi Version Time is now: 17th March 2026 - 06:15 AM
