> Rear Caliper Rebuild, "How-To Thread"
Eric_Shea
post Jan 25 2005, 11:07 PM
PMB Performance
In an earlier thread I was asked to write a “How-To” thread on the rear caliper rebuild. I had to get some pictures together before this made sense.
I’m starting this thinking you’ve already gotten them off the car and you understand how to reinstall them and bleed your brakes. This is all about the caliper rebuild. This is also about a “top-end” caliper rebuild. If your caliper is leaking through the handbrake lever I would consider getting a new core at least. Why? Rebuild kits are around $22.00. Handbrake rebuild kits are around $50.00. Now you’re in it for close to $80.00 with shipping etc. A rebuildable core should go for $20-$40 bucks… as these get scarce you may want to reconsider but currently they’re not too scarce.
This job is not fun and it’s not all that easy. It’s not too tough either, it just requires some mechanical ability, patience, special tools and some “tricks of the trade”. Yes, I rebuild these so I’m either loosing customers or gaining customers by writing this (I’m obviously not too concerned). Follow the thread. If it’s something you want to tackle then dive in. If not, you know where to go.
Here are some of the tools you’ll need:
 Dental Pick
 T27 Torx Driver (early single bleeder style)
 Torque Wrench
 4mm Hex key
 Small and Large Locking Pliers
 Brake Grease
 Brake Cleaner
 Large Screwdriver
 Small Wire Brush
 13mm Socket
 11mm Deep Well Socket (to press the spring and cover into the inner caliper half)
 11mm Socket
 MAP Torch
 Air Wrench
 Pistol Grip Clamp
 Brake Caliper Hone
 Hand Drill
 Two Rear Caliper Rebuild Kits from Your Favorite Vendor (they must include all seals)
 7mm Wrench (for the bleeder valve. I prefer to use a small pair if locking pliers though…)
Here’s the “How-To”
1. Drain it. You’ll want to get all the fluid out of these before you dig into the task at hand. As mentioned above, take a pair of locking pliers and snug them down on the bleeders. Most are stuck and this is the only way to go. The 7mm wrench will rarely do the trick. Once you get them off, try to blow some air through them.
2. I like to mount these in a vise before I start the dismantling process. Next I start with the caliper half bolts. These are 11mm bolts on the later style (dual bleeder) or T27 Torx bolts on the early calipers (single bleeder). The early calipers have 11mm nuts on them. These will seem impossible to remove. Here’s where the MAP torch comes into play. Don’t worry too much about heating these puppies up. First of all, brakes get hot. Second, you have new seals in your rebuild kits. You just don’t want to heat up the parking brake area because as discussed earlier, that’s another $50.00 in parts and another rebuild. Heat the bolts and use your air wrench to hammer these off. Split the caliper and remove the inner seals. While you’re at it, remove the dust boots and clamps using the dental pick.
Eric_Shea
post Jan 25 2005, 11:15 PM
PMB Performance
6. Optional. If you’re going to plate or paint your calipers (and why wouldn’t you while they’re apart) then you’ll probably want to take the handbrake spring off. To do this you’ll need to remove yet another clip (ATE seems to love clips), slide off the washer and then use the small locking pliers and grab the spring just past the bend and pull up. The tension is not that great so don’t worry about it flying across the garage. Next remove the spring rest from the shaft.
Eric_Shea   Rear Caliper Rebuild   Jan 25 2005, 11:07 PM
Eric_Shea   3. Turn out the pistons. The heat you used on the...   Jan 25 2005, 11:08 PM
Eric_Shea   Turning out the piston... (and yes, these will cle...   Jan 25 2005, 11:09 PM
Eric_Shea   Gently rock back and forth.   Jan 25 2005, 11:10 PM
Eric_Shea   4. Remove the adjusters. The outer adjuster will ...   Jan 25 2005, 11:11 PM
Eric_Shea   Inner...   Jan 25 2005, 11:12 PM
Eric_Shea   Inner adjuster pulled out... see the sausage?   Jan 25 2005, 11:13 PM
Eric_Shea   5. Use the ever so handy dental pick to remove the...   Jan 25 2005, 11:14 PM
Eric_Shea   6. Optional. If you’re going to plate or paint ...   Jan 25 2005, 11:15 PM
Eric_Shea   7. You Decide. You now have a totally stripped pa...   Jan 25 2005, 11:17 PM
Aaron Cox   sissy boy - uses latex gloves.... ...   Jan 25 2005, 11:18 PM
drgchapman   Looks like I won't try this at home, calipers ...   Jan 25 2005, 11:19 PM
Eric_Shea   9. Install the piston seals from your kit. They d...   Jan 25 2005, 11:20 PM
Eric_Shea   Inner Adjuster Rig...   Jan 25 2005, 11:22 PM
Eric_Shea   11. Install the pistons. I tape them off and bead...   Jan 25 2005, 11:23 PM
swood     Jan 25 2005, 11:48 PM
SpecialK   I'll check out some local places, beats the Ea...   Jan 26 2005, 01:04 AM
9146986   http://www.914w...   Jan 26 2005, 03:39 PM
Eric_Shea   Thanks! I'm glad the thread is of interes...   Jan 26 2005, 03:47 PM
skline   So Eric, do you sell the little sweaters to put on...   Jan 26 2005, 03:50 PM
Eric_Shea   I should but then it would cover up their beauty. ...   Jan 26 2005, 04:05 PM
DJsRepS   That was an fantastic journey through the rebuild ...   Jan 27 2005, 07:26 AM
Eric_Shea
  Jan 27 2005, 10:59 AM
dinomium   Thanks for the timely post! I was just gonna a...   Jan 27 2005, 10:32 PM
dinomium   Ok that was too easy!!
  Jan 30 2005, 01:30 PM
pete-stevers   Fantastic thread Eric... can't wait to get the...   Jan 30 2005, 02:44 PM
the colonel   fantastic thread. wish me luck. i will soon be e...   Aug 13 2013, 02:08 PM
Eric_Shea   Sorely outdated. Use this instead: dm_DnizKOZM   Aug 13 2013, 05:00 PM
76-914   Here's some of Eric's product   Aug 13 2013, 05:51 PM
- Lo-Fi Version Time is now: 10th November 2026 - 04:24 AM
