| JCHinCT |
Nov 19 2023, 12:35 PM
Newbie ![]() Group: Members Posts: 8 Joined: 25-January 17 From: CT Member No.: 20,783 Region Association: North East States
I am starting restoration work on the first car I owned, a 1975 2.0L that I bought in 1979. Though it hasn't run since the mid 1980s. I finally got the car on a rotisserie, and I've just started a long slog to get the undercoating and seam sealer off.
I would appreciate some advice re metal prep. My plan is to eventually have the car media blasted prior to priming and finish paint. But in the near term I plan to attack each structural rust patch, and one-by-one weld in new metal, then hit each with some kind of primer. The goal is to protect each fixed patch temporarily while I go on to the next one. And since this process might take a long time, many months, I need to protect against encouraging rust on the newly patched zones. Only after I think I've got all the patch welds done will I take it for media blasting down to bare metal all over, prior to finish painting. So here are a few questions: - is there any concern about the type of temporary primer I use while the car is piecemeal patch welded? Or is it better to use some zinc or phosphate coating instead of temporary primer? - I do not have a paint shop lined up yet. Is it advisable to find a shop that wants the job, and ensure I'm using a suface prep that is agreeable to the planned paint system? Or can that be dialed in just before media blasting? (I’m worried a reputable paint shop won’t want to deal with a car that they haven’t controlled through the media blasting phase.) - any advice on getting inside the longitudinals to try to remove interior surface rust, and treat it, without actually cutting and opening the longs up? (I think a dumb question but thought I'd throw it out there anyway) - similar question: after 15 minutes of shop-vacuuming, I think I see mild surface rust under the headlight buckets ... how do you get in there and deal with it properly? - regarding sheet metal for the weld patches: I plan on 18 gage for structural areas, and 16 for non-structural ... but plain old low carbon steel? or should one aim for something with a rust-preventative coating on it - even though it needs to be MIG welded? - I found some horrible rust in the front trunk compartment, under the seam sealer on the driver's side. Rusted through, with a couple of index-finger-sized holes. Obviously, this needs to be totally removed and creative weld-in patches made. However, in other places the seam sealer looks really solid with no sign of the "rust-crunch" sound underneath. Option 1: just leave the “good” seam sealer, and later media blast it and paint over it. Option 2: dig it out even though its probably fine, assess the metal underneath, and then later apply more seam sealer over it before painting? What do you think? This is especially a question at the rear shock towers, that seem almost like they're new and almost certainly rust free (though, how really can one tell without digging in?) Thx in advance. |
| mlindner |
Nov 24 2023, 12:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
And when your finished, you will love it. Mine took five years of part time work, accumulate parts, lots of cleaning/refresh and then off to painter and then reassemble. I've also owned mine for 45 years. Mark
JCHinCT Starting a restoration project Nov 19 2023, 12:35 PM
mepstein :wttc:
There are a ton of restoration threads on... Nov 19 2023, 12:58 PM
Montreal914 :wttc:
You found the right place to get the supp... Nov 19 2023, 01:05 PM
fiacra Wow, rare to still have your first car after 44 ye... Nov 19 2023, 03:04 PM
Dion :Qarl: :wttc: welcome.
As Mark said read and st... Nov 19 2023, 03:40 PM
Dlee6205 "is there any concern about the type of tempo... Nov 19 2023, 06:39 PM
campbellcj :wttc: Looking forward to following your project... Nov 20 2023, 07:45 AM
ChrisFoley Where are your chassis braces for the door opening... Nov 20 2023, 04:16 PM
930cabman :wttc:
Looks like you were not bashful and jumpe... Nov 20 2023, 05:22 PM
jd74914 :welcome:
Whereabouts in CT are you located? Ther... Nov 20 2023, 08:18 PM
bkrantz Like others have said
1. Brace the door openings.
... Nov 20 2023, 08:39 PM
JCHinCT Thanks for all the responses and the links to key ... Nov 24 2023, 09:32 AM
mlindner Sounds like you have a good handle on it. I had to... Nov 24 2023, 12:07 PM
930cabman
Sounds like you have a good handle on it. I had t... Nov 26 2023, 02:25 PM
Freezin 914 :wttc: Nov 24 2023, 12:10 PM
bkrantz That's it--embrace the challenge! And sta... Nov 24 2023, 09:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th October 2026 - 02:15 AM |
