> Lilchopshop’s Subaru Conversion Project, Making it up as I go
Lilchopshop
post Dec 3 2023, 08:15 PM
Hi All,
My name is Aaron. I've been lurking on this site for years, learning from all of you who are kind enough to share your projects and the challenges that go along with them. In an attempt to keep me motivated on my project and as a way to create a place for me to ask questions as they come up (which they will, frequently), I decided it was time to start a proper build thread. I’m not a novice when it comes to tools, fabricating and most things automotive, but I’ve never attempted an engine swap before, and most things electrical tend to stress me out. That being said, I love a good challenge and I’m not afraid to fail.
I purchased this car in February of 2020, just before Covid lockdown. I got off to a pretty good start repairing the rust and trying to make a solid chassis for what I thought was going to be a stock-ish restoration (some of that work documented here: http://www.914world.com/bbs2/index.php?sho...ty+jack+points). Then, after watching all the great engine-swap builds on this site, I changed my mind. I knew I wanted more horsepower, but I couldn’t justify the cost of an air-cooled Porsche 6-cyl and I didn’t want to lose the trunk to a big V8. For a while, I was considering keeping the original engine from the car and using a tunable fuel injection package, but for the total cost, the bang for the buck just didn’t seem there. So, I settled on the Suby engine. After some research and some purchasing mistakes, I ended up buying a 2002 legacy outback donor vehicle with an EG25 engine. I harvested the engine, the ECU and whatever else seemed valuable. After selling off the old Porsche engine, transmission, all of the FI components and the saleable parts from the donor Subaru, I probably ended up in the black, financially.
Since buying the car in 2020, I’ve gotten pulled away by many other, more important projects, so I’ve only been able to do little stints of work on the car. I’m optimistic this time, that I will be able to finally dedicate some quality time this winter and hopefully make some real headway. I haven’t been great at documenting the little things I’ve done on the car in the last 2 years, so I’ll start this thread off with some of the things I did actually get pictures of and a summary of where I’m at now.
The day we met: Attached Image
The first attempt at a Suby Engine (EJ22): Attached Image
The second attempt (complete donor vehicle):Attached Image
My crazy, home-built cable shift linkage:Attached Image
My home-built engine cradle: Attached Image
Shifter from a boxter (slightly modified): Attached Image
Some suspension ear reinforcement: Attached Image
technicalninja
post Dec 4 2023, 09:07 PM
Tygaboy is right!
Every cylinder has an "optimal" primary diameter and length for maximum VE at a specific RPM range in the engine.
A primary length for 3-4k RPM will be different than the exact same engine at 5-6K.
If you're racing and always above 5k you need one length, and a streetcar will have better overall performance with something quite different.
How much of an improvement is the real question here. The OEMs break these rules all the time with weirdly different length primaries that seem work OK in real life.
Yours are already built; I'd try them like they sit.
It almost looks like you went slightly larger on the exit tube past where the primaries blended?
I think that will actually function OK.
I think you will be fighting cracks just past the blend from now on...
That area will be getting double the heat versus separate longer primaries.
I'd still want to try it if I was in your shoes.
Sounds like making a dedicated tuned length separate primary header might be a bitch with that engine.
I'd look at a NA Subaru high performance header (if such a beast exists) for primary dimensions.
Lilchopshop   Lilchopshop’s Subaru Conversion Project   Dec 3 2023, 08:15 PM
Cairo94507   Great; we all love build threads with lots of phot...   Dec 4 2023, 10:28 AM
gereed75   Nice work so far. That shift linkage looks really ...   Dec 4 2023, 10:47 AM
76-914   Looks great. Will you be able to drop straight dow...   Dec 4 2023, 03:39 PM
Lilchopshop   Looks great. Will you be able to drop straight do...   Dec 4 2023, 04:32 PM
76-914   Nice looking fab work you have there. Weld the bun...   Dec 4 2023, 06:56 PM
tygaboy   Do these Subaru engines not benefit from the ol...   Dec 4 2023, 07:03 PM
Lilchopshop   @76-914 , thanks for the O2 sensor placement advic...   Dec 4 2023, 07:50 PM
technicalninja   Tygaboy is right! Every cylinder has an ...   Dec 4 2023, 09:07 PM
Lilchopshop   Tygaboy is right! Every cylinder has an ...   Dec 5 2023, 07:48 AM
76-914   You could put 3 into 1 and it will still outperfor...   Dec 5 2023, 08:49 AM
76-914   You could put 3 into 1 and it will still outperfor...   Dec 5 2023, 08:50 AM
technicalninja   6 cylinder or less should be run through a single ...   Dec 5 2023, 10:44 AM
Lilchopshop   As I contemplate design changes to my exhaust, I d...   Dec 6 2023, 07:48 PM
Lilchopshop   I’ve had more distractions lately than I expecte...   Jan 27 2024, 11:22 AM
Lilchopshop   Couple more pics of the complete exhaust system. ...   Jan 27 2024, 11:27 AM
Lilchopshop   After finishing the exhaust, I felt like I needed ...   Jan 27 2024, 11:39 AM
76-914   Your fabrication work kooks good. Exhaust routing ...   Jan 27 2024, 12:15 PM
East coaster   Looks good! I just wrapped up my Suby exhaust ...   Jan 27 2024, 05:32 PM
Maltese Falcon   Buddy of mine in New Mexico is building "Phys...   Jan 27 2024, 06:33 PM
Lilchopshop   It’s been a while since my last post, but I’ve...   Mar 9 2024, 07:54 AM
76-914   It's good that you're back on it. Should b...   Mar 9 2024, 08:08 AM
Lilchopshop   Well, a year went by since my last post… good th...   Mar 13 2025, 04:48 PM
Lilchopshop   Next up, I thought I’d start figuring out radiat...   Mar 13 2025, 05:40 PM
Cairo94507   Very nice progress. I especially like the new tai...   Mar 13 2025, 06:18 PM
FL000   I believe the Subarus run pretty cool (compared to...   Mar 13 2025, 07:28 PM
914werke   It’s been a while since my last post, but I’v...   Mar 13 2025, 08:38 PM
Lilchopshop   It’s been a while since my last post, but I’...   Mar 14 2025, 07:50 AM
East coaster   I hid mine under a custom center console. Mine is ...   Mar 14 2025, 09:18 AM
Lilchopshop   I hid mine under a custom center console. Mine is...   Mar 14 2025, 09:35 PM
76-914   You should be able to cool the 2.5 with a much sma...   Mar 14 2025, 09:15 PM
Lilchopshop   April '25 update: I've been able to spend...   Apr 17 2025, 06:19 AM
East coaster   Looking good!   Apr 17 2025, 09:16 AM
slowrodent   Very very nice work.... :beer2:   Apr 17 2025, 10:00 AM
Lilchopshop   Well, it’s been a while since my last update her...   Jan 21 2026, 05:00 PM
Lilchopshop   Enough of that. Here’s the progress on the car...   Jan 21 2026, 05:52 PM
Lilchopshop   With the radiator and tunnel in place, I mocked up...   Jan 21 2026, 06:35 PM
worn   Very nice. I see quality in every post.   Jan 21 2026, 06:43 PM
tygaboy   Lovely bead work! Looks REALLY good. :headban...   Jan 21 2026, 07:28 PM
Ninja   With the radiator... Next up, I’m making the...   Jan 21 2026, 08:14 PM
rick 918-S   Nice project. That will be very fast! Kent...   Jan 22 2026, 06:02 AM
Lilchopshop   Thanks guys! Means a lot to me coming from al...   Jan 22 2026, 08:56 AM
Lilchopshop   Hi All, Made some more progress over the last few ...   Feb 10 2026, 07:20 PM
Lilchopshop   The other project I’ve been working on is a 3D p...   Feb 10 2026, 07:40 PM
Lilchopshop   Been making some progress on the bumper/spoiler/gr...   Feb 28 2026, 11:21 AM
Montreal914   Just went through the thread. Very nice custom fab...   Feb 28 2026, 11:57 AM
Lilchopshop   A little more progress on the bumper/grille/spoile...   Mar 6 2026, 05:39 PM
tygaboy   Is your printer in your shop or house? I'm pla...   Mar 6 2026, 06:36 PM
Lilchopshop   Is your printer in your shop or house? I'm pl...   Mar 6 2026, 08:43 PM
tygaboy   [quote name='tygaboy' post='3248091' date='Mar 6 ...   Mar 6 2026, 10:21 PM
Lilchopshop   Another update. Still working in the frunk. As mu...   Mar 22 2026, 07:10 PM
Lilchopshop   It’s been a minute since my last update, but the...   May 19 2026, 08:53 PM
East coaster   Kudos for the creativity!   May 20 2026, 03:43 AM
rick 918-S   I like the hammer form.   May 20 2026, 05:52 AM
Chris H.   Very very nice fabrication work. :trophy:   May 20 2026, 06:11 AM
Lilchopshop   Thanks for the kind words! The wood buck wo...   May 20 2026, 07:42 AM
Lilchopshop   It’s all about the journey, right? So, I’m al...   May 28 2026, 07:09 PM
Jack Standz   We use a dedicated oven we got for free that only ...   May 29 2026, 01:51 PM
Lilchopshop   We use a dedicated oven we got for free that only...   May 29 2026, 05:36 PM
Lilchopshop   A couple of little projects before I pull the engi...   May 30 2026, 03:29 PM
Lilchopshop   Well, it’s been a minute since my last post. I ...   Nov 11 2026, 12:30 PM
Lilchopshop   Before I close up the driver’s side longitudinal...   Nov 11 2026, 01:09 PM
7 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 11th November 2026 - 01:09 PM
