DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
I looked high and low in the workshop manuals but could not find mention of the distributor cap wiring connections for the 914-6. Is the wiring order and clockwise rotation shown in the photo below correct? I took this from a 911 sticker.
![]() I am creating a quick reference sheet for myself as I prepare to reassemble our engine. P.S. Believe it or not, not all 911 are the same. I guess the SC turns counter clockwise? |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,269 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
I looked high and low in the workshop manuals but could not find mention of the distributor cap wiring connections for the 914-6. Is the wiring order and clockwise rotation shown in the photo below correct? I took this from a 911 sticker. ![]() I am creating a quick reference sheet for myself as I prepare to reassemble our engine. P.S. Believe it or not, not all 911 are the same. I guess the SC turns counter clockwise? That is the correct rotation and firing order on a -6. Once you line up the #1 position on the distributor with the TDC mark on the flywheel, you are good. However, make sure you properly identify the cylinder locations. According to the sticker on mine, #1 is the rear most on the driver side, (as referenced with the engine installed, fan facing forward). Fan 3 6 2 5 1 4 |
Lo-Fi Version | Time is now: 12th May 2025 - 06:00 AM |
