Clutch Install Issues, Pressure plate not in contact with flywheel |
RKramden |
Dec 12 2023, 09:33 PM
Newbie Group: Members Posts: 41 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
I am having issues with my new clutch. After tightening to torque (18fp) the pressure plate is still not in contact with the flywheel (aprox. 1mm gap). Is this normal? If not, should I continue to tighten until it bottoms on the flywheel?
When I first installed, it was almost a 1/4" gap at torque, so I put some clamps on it and I got the internals of the pressure plate to move that I now assume were somehow frozen. Any advice would be greatly appreciated. |
RKramden |
Dec 14 2023, 09:43 PM
I will change the bolts once I get the tightening to the flywheel issue resolved. They currently do not bottom out or hit the case. Thanks to Glen at Pelican for cross checking the Sachs part #s.
Tomorrow I will take the pressure plate to the machine shop to put on the press to see if there is enough flex to to actually compress down to the flywheel Thanks all for your input…. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:55 AM |
