> Rust in the Tunnel Repair, my grinder doesn't fit in [I]there[I]
jandro62
post Jan 27 2005, 09:02 AM
So I popped the access panels off the tunnel, and despite the tunnel looking solid from the top, and solid from the underside of the car, there is soooo much rust in there. I had a field day with the magnetic pickup removing all sorts of crap. I even found a walnut shell, don't know how that got in there. Its enough rust that it worries me. Is this tunnel thing separate from the floorboards? How would I go about replacing it? Hell, do I try and plasma torch one side off of it to get at the rust and try and tack it back together?
Thanks,
Alex
Joe Ricard
post Jan 27 2005, 11:14 AM
CUMONIWANNARACEU
The tunnel is separate from the floor boards. If'n you can weld this shouldn't be a problem. Only other optionis to vaccumit all out spray som metal prep and Por-15 what you can reach.
jandro62   Rust in the Tunnel Repair   Jan 27 2005, 09:02 AM
Joe Ricard   The tunnel is separate from the floor boards. If...   Jan 27 2005, 11:14 AM
SirAndy   http://www.914world.com/bbs2/h...   Jan 27 2005, 03:01 PM
xsboost90   get a quart of POR15, dump it in the hole by the s...   Jan 27 2005, 04:18 PM
swood   If'n it's just surface rust, it's no b...   Jan 27 2005, 04:30 PM
jimtab   Just for general rustprofing info, Rustoleum has r...   Jan 27 2005, 08:07 PM
DJsRepS   How does one cut and weld around the plastic fuel ...   Jan 28 2005, 04:40 AM
rdauenhauer   You dont http://www.914world.com/bb...   Jan 28 2005, 11:06 AM
jimtab
- Lo-Fi Version Time is now: 11th July 2025 - 04:28 PM
