mmascari |
Member ![]() ![]() Group: Members Posts: 322 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None ![]() |
I have a 914 with a 3.0l six and PMO carbs. The gas smell is unbearable, especially when the car is in the garage. My wife is about to lose her mind. What do you carb guys do to limit this? Would running the engine with the fuel pump off, IE running out of fuel help with this situation?
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Porsche 356 has carbs and a fuel shutoff underneath the dash.
With today’s fuel, I find it best with any carbed engine to turn off the fuel supply while the engine is running and let it suck the carbs dry. Also, when going to a car show, simply putting tennis balls into the intake stacks helps a TON to keep the hot fuel from evaporating and smelling things up. Today’s gas has a lot of ethanol. That evaporates really fast. Rich |
73-914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None ![]() ![]() |
Porsche 356 has carbs and a fuel shutoff underneath the dash. With today’s fuel, I find it best with any carbed engine to turn off the fuel supply while the engine is running and let it suck the carbs dry. Also, when going to a car show, simply putting tennis balls into the intake stacks helps a TON to keep the hot fuel from evaporating and smelling things up. Today’s gas has a lot of ethanol. That evaporates really fast. Rich (IMG:style_emoticons/default/agree.gif) This is why I use alcohol-free gas |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,414 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Porsche 356 has carbs and a fuel shutoff underneath the dash. With today’s fuel, I find it best with any carbed engine to turn off the fuel supply while the engine is running and let it suck the carbs dry. Also, when going to a car show, simply putting tennis balls into the intake stacks helps a TON to keep the hot fuel from evaporating and smelling things up. Today’s gas has a lot of ethanol. That evaporates really fast. Rich (IMG:style_emoticons/default/agree.gif) This is why I use alcohol-free gas There is a fairly new station near me that sells ethanol free gas. We make sure to fuel the factory six there and nowhere else unless forced to. But it is only 90 octane, so we have to put in octane boost with each tank. But it is worth it. |
Jamie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States ![]() ![]() |
Porsche 356 has carbs and a fuel shutoff underneath the dash. With today’s fuel, I find it best with any carbed engine to turn off the fuel supply while the engine is running and let it suck the carbs dry. Also, when going to a car show, simply putting tennis balls into the intake stacks helps a TON to keep the hot fuel from evaporating and smelling things up. Today’s gas has a lot of ethanol. That evaporates really fast. Rich (IMG:style_emoticons/default/agree.gif) This is why I use alcohol-free gas There is a fairly new station near me that sells ethanol free gas. We make sure to fuel the factory six there and nowhere else unless forced to. But it is only 90 octane, so we have to put in octane boost with each tank. But it is worth it. I've been running my 914 on locally available 90 octane no ethanol fuel for some time, but wondering about using it in my new Cayman 718 turbo? How about alternating fill-ups to keep the octane up? (IMG:style_emoticons/default/confused24.gif) |
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,816 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
I've been running my 914 on locally available 90 octane no ethanol fuel for some time, but wondering about using it in my new Cayman 718 turbo? How about alternating fill-ups to keep the octane up? (IMG:style_emoticons/default/confused24.gif) I'm not sure what the advantage would be of putting ethanol-free fuel in a modern car. They're designed for the blended fuels. And being fuel injected, evaporation isn't a concern. |
Lo-Fi Version | Time is now: 1st July 2025 - 07:04 AM |
