63acornwall |
Member ![]() ![]() Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None ![]() |
Hi all , I have a recurring problem with ignition light not coming on when starting up , and when this happens the voltmeter also shows no charging taking place - blip of throttle does not alter volt reading
When this first happened 10 months ago , it was transient - did not happen everytime . Then it became permanent , I checked the ignition light bulb with a circuit tester and it was fine , just not seeing any current . Took car to an aircooled 911 specialist - its a 1975 914 retrofitted with a 1975 2.7 litre 6 from a 911 My local Porsche specialist replaced the alternator and all was good again , then the problem recurred 3 months ago. This time it was a broken brass contact tag on the earth side of the bulb circuit - replaced tag and all working Now the problem is back . I pulled out the dial and studied the spaghetti of wiring, the new brass tag still there ok , bulb still ok , but the live connection to bulb not live when ignition on The electric fuel pump starts up , the starter motor starts up , the dash lights all work , the indicator lights etc all work . I have not checked the generator drive belt , its a bit hard to get at , assume if it was ok when alternator replaced the still ok ! I have a Haynes manual with 1975 circuit diagrams as my only guide to the electrical circuit , not sure where to look before getting towed back to another specialist Any suggestions ? |
Lo-Fi Version | Time is now: 17th July 2025 - 06:45 AM |
