> Auxiliary Air Valve question
torakki
post Feb 1 2024, 07:41 PM
This is on a '74 2.0. This car's been on and off the back burner for a number of years. (To many cars). It now runs very well, "Except", when it's cold, it idles perfect. As it warms, (about 2 minutes) the idle gets faster to about 1800 rpm. After a 15-to-20-minute drive, I shut it off. Restart a few minutes later and the idle is slow to wont idle fast enough to keep running. So, I'm checking the Auxiliary air valve (I took it apart) and when it's cold, it's open halfway. When it gets warm, it closes. Shouldn't it be opening when warm to let in more air to keep the idle speed up? In other words, lean out the mixture? I would think, when cold, it should be closed to richen up the fuel and warm, open to lean out.
Am I 180 degrees off?
Thanks for any input.
torakki
post Feb 2 2024, 06:14 PM
I am kinda leaning towards, no leaks, since I installed a new vacuum line kit on the engine and have gone through it multiple times. Also, when I pull the vacuum hose off the AAV, (creating a leak), engine idles at 2K.
I've replaced the CHT sensor twice, new MPS, replaced the, I believe it's called, ambient air temp sensor and all the normal things like ign. wires, plugs, cap, rotor, points and everything I could think of.
I wonder if poor valve adjustment could cause slow idle? Sometimes I imagine some clatter but then I think, no, that's a normal sound.
Thanks for all the replies. Now I know how the AAV works.
torakki   Auxiliary Air Valve question   Feb 1 2024, 07:41 PM
JeffBowlsby   The AAR closes when warm. When cold, it’s open.   Feb 1 2024, 07:49 PM
emerygt350   Yeah. Sounds like it is working. These are notorio...   Feb 1 2024, 07:56 PM
914work   its a designed vacuum leak, for higher idle when c...   Feb 2 2024, 12:01 AM
Geezer914   I second a vacuum leak. Do a smoke test, search Y...   Feb 2 2024, 06:17 AM
emerygt350   The aar is a controlled vacuum leak. A crummy low...   Feb 2 2024, 03:33 PM
torakki   I am kinda leaning towards, no leaks, since I inst...   Feb 2 2024, 06:14 PM
emerygt350   Did you read my posts? This is a known issue. It...   Feb 2 2024, 07:30 PM
rjames   Start with basics- setting the timing and the valv...   Feb 2 2024, 08:00 PM
iankarr   You can see more about how the AAR works in this v...   Feb 3 2024, 02:48 PM
r_towle   Have you removed, cleaned, and re-greased the adva...   Feb 3 2024, 07:00 PM
emerygt350   That dist. Plate cleaning and greasing is just a g...   Feb 4 2024, 09:25 AM
torakki   Yes, I did read but confusing. So, heads cool, it...   Feb 5 2024, 08:37 PM
rjames   Did it ever run correctly? If yes, what changed si...   Feb 5 2024, 10:25 PM
emerygt350   When you say "I remove the hose when warm...   Feb 6 2024, 01:03 PM
torakki   [/quote] Yes, to the intake plenum. And yes, th...   Feb 8 2024, 07:32 PM
StarBear   Nice job! A big huzzah for getting another one...   Feb 9 2024, 07:34 AM
emerygt350   what a beauty. Here is my suspicion. Your aar ...   Feb 9 2024, 10:51 AM
FlacaProductions   One other scenario concerning the distributor - yo...   Feb 9 2024, 11:51 AM
torakki   My brains getting old so I may have to print that...   Feb 11 2024, 06:50 PM
- Lo-Fi Version Time is now: 6th July 2025 - 04:01 PM
