torakki |
Member ![]() ![]() Group: Members Posts: 62 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California ![]() |
This is on a '74 2.0. This car's been on and off the back burner for a number of years. (To many cars). It now runs very well, "Except", when it's cold, it idles perfect. As it warms, (about 2 minutes) the idle gets faster to about 1800 rpm. After a 15-to-20-minute drive, I shut it off. Restart a few minutes later and the idle is slow to wont idle fast enough to keep running. So, I'm checking the Auxiliary air valve (I took it apart) and when it's cold, it's open halfway. When it gets warm, it closes. Shouldn't it be opening when warm to let in more air to keep the idle speed up? In other words, lean out the mixture? I would think, when cold, it should be closed to richen up the fuel and warm, open to lean out.
Am I 180 degrees off? Thanks for any input. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Have you removed, cleaned, and re-greased the advance plates in the distributor?
Lo-Fi Version | Time is now: 6th July 2025 - 03:23 PM |
