My Recent Purchase - 1976 914 |
914_Tcup |
Feb 17 2024, 09:45 PM
Newbie Group: Members Posts: 18 Joined: 24-November 23 From: T-Town (Tulsa OK) Member No.: 27,754 Region Association: Southwest Region |
Oops...double post
StarBear |
Feb 18 2024, 08:36 AM
Senior Member Group: Members Posts: 1,914 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
A ‘76 1.8?? I thought they produced only 2.0 units in 76. I could be wrong?
@wonkipop ? Maybe it’s had its engine replaced? |
wonkipop |
Feb 19 2024, 04:56 PM
Advanced Member Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
A ‘76 1.8?? I thought they produced only 2.0 units in 76. I could be wrong? @wonkipop ? Maybe it’s had its engine replaced? def had its engine replaced. check dashboard gauges. has a temp gauge instead of hand brake flasher. no 1.8s ever came with the dash pod temp gauge. (only a temp gauge in console if you ordered the appearance group). was once a 2.0 |
914_Tcup |
Feb 19 2024, 08:37 PM
A ‘76 1.8?? I thought they produced only 2.0 units in 76. I could be wrong? @wonkipop ? Maybe it’s had its engine replaced? def had its engine replaced. check dashboard gauges. has a temp gauge instead of hand brake flasher. no 1.8s ever came with the dash pod temp gauge. (only a temp gauge in console if you ordered the appearance group). was once a 2.0 It has the front stabilizer bar (also it has a rear stabilizer). Is the front stabilizer a stock item with the 2.0 ? |
wonkipop |
Feb 19 2024, 08:50 PM
A ‘76 1.8?? I thought they produced only 2.0 units in 76. I could be wrong? @wonkipop ? Maybe it’s had its engine replaced? def had its engine replaced. check dashboard gauges. has a temp gauge instead of hand brake flasher. no 1.8s ever came with the dash pod temp gauge. (only a temp gauge in console if you ordered the appearance group). was once a 2.0 It has the front stabilizer bar (also it has a rear stabilizer). Is the front stabilizer a stock item with the 2.0 ? i think not. think you had to tick the box. my 74 1.8 has front and rear stab bars. owner checked a box when she ordered. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:06 AM |
