> Need engine misfiring advice
oakdalecurtis
post Feb 22 2024, 02:50 PM
Oakdalecurtis
Here’s a question for the braintrust.
I have a 1974 stock FI original motor, 130,000 miles. It has a Crane Fireball ignition and Novolny plug wires. It has always run flawlessly from startup. Lately, upon cold start, it has been badly and randomly “missing” for the first 2 minutes, especially on acceleration. It is not a constant steady miss on one cylinder. I can’t say that is isn’t one cyclinder doing the missfiring, but the miss is random, 2 seconds, 4 seconds, 3 seconds apart. Then it runs flawlessly after the first 2 minutes.. The AAR valve works fine. The MAPS board has been replaced with a new one a while back. I have checked that all the plug and coil wires are tight. I thought maybe some long term water concensation in the gas tank might settle and cause an issue. I added a fuel additive to prevent that, made no difference.
What do these clues indicate on where to start looking for the this inital start random misfiriing?
oakdalecurtis
post Feb 22 2024, 08:54 PM
Oakdalecurtis
Correct, Crane replaced the point only, rest stock. Could a fouled sparkplug only causes missing for the first 2 minutes and then become perfect after that. If you say yes, I will pull and check them first and report back…
- Lo-Fi Version Time is now: 17th July 2025 - 04:59 AM
