| morehills |
Feb 29 2024, 06:30 AM
Member ![]() ![]() Group: Members Posts: 134 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States
I'm doing a fairly large project on the interior of my 1971 914-6 GT clone this winter. I'm converting to 911 steering and ignition, adding a GT roll bar and harness mounts and a few other bits and bobs.
While it's open, should I cut an access panel? Is there any impact on the structural integrity of the firewall? How difficult is it to lean over the engine and adjust timing without the access panel? While it would be more convenient, I wonder if it's really needed to properly time the car every few years. It's a '71 2.2 liter "E" cam engine. Thanks for any advice. John Attached image(s)
| rgalla9146 |
Feb 29 2024, 10:47 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
IF you choose to put the access hole in, there is no better cover than a piece
cut out of a junked car . It will fit perfectly and look like it grew there. Timing and valve adjustment can be made much easier by marking your flywheel as done on original 914 6s Use the marks on your crank pulley to position the flywheel for marking. No need to be young, thin or acrobatic. Changing / adjusting your fanbelt is a challenge. Get the right tools. If using an aftermarket front mount be sure there is clearance to remove /install the V belt Practice replacing and adjusting before leaving on long journeys. |
morehills 914-6 Hole in Firewall Feb 29 2024, 06:30 AM
Cairo94507 If you have a factory 914-6, I would not cut the f... Feb 29 2024, 06:43 AM
gereed75 There are lots of threads and lots of opinions on ... Feb 29 2024, 06:59 AM
Superhawk996
There are lots of threads and lots of opinions on... Feb 29 2024, 07:06 AM
brant Drop the motor for valve adjustment
Geez. I do ... Feb 29 2024, 07:24 AM
Superhawk996 I haven’t read that thread in a while.
Here’... Feb 29 2024, 08:29 AM
Steve I've had my 914-6 conversion since 1986 and on... Feb 29 2024, 09:06 AM
worn
I've had my 914-6 conversion since 1986 and o... Feb 29 2024, 08:58 PM
Steve I bought the PMS fiberglass cover, versus finding ... Feb 29 2024, 09:08 AM
morehills
I bought the PMS fiberglass cover, versus finding... Feb 29 2024, 09:25 AM
gereed75 Do my valves routinely in car also. I guess I was ... Feb 29 2024, 09:51 AM
SirAndy Is there any impact on the structural integrity of... Feb 29 2024, 10:28 AM
ClayPerrine
[quote name='morehills' post='3131423' date='Feb ... Mar 1 2024, 08:39 AM
Superhawk996
So what is the big deal with just disconnecting t... Mar 1 2024, 09:03 AM
ClayPerrine
So what is the big deal with just disconnecting ... Mar 1 2024, 05:34 PM
fixer34
[quote name='morehills' post='3131423' date='Feb... Mar 3 2024, 09:21 PM
930cabman I cut mine for the /6 conversion. It's a simpl... Feb 29 2024, 10:57 AM
Superhawk996 Ya all must be changing fan belts like underwear t... Feb 29 2024, 11:17 AM
mlindner I put one in my GT Tribute, helps a lot with servi... Feb 29 2024, 11:40 AM
brant Ours Feb 29 2024, 12:10 PM
930cabman
Ours
Looks very clean to me, I can't see ho... Feb 29 2024, 04:21 PM
burton73
Ours
Looks very clean to me, I can't see h... Feb 29 2024, 07:13 PM
Beach914 I'm planning to do it on my GT conversion but ... Feb 29 2024, 12:25 PM
dr914@autoatlanta.com NO WAY!!!!!!
I'm doi... Feb 29 2024, 12:28 PM
burton73 @morehills
I have what you want. I was going to ... Feb 29 2024, 03:07 PM
Mitox I cut mine, and found a firewall section to make t... Feb 29 2024, 04:56 PM
Dion My version. Had a section from a donor car. Added ... Mar 1 2024, 06:22 AM
mepstein Yes it’s called a firewall. Yes a plate that’s... Mar 1 2024, 08:53 AM
mb911 I have always been tempted but have stayed away fr... Mar 3 2024, 07:03 AM
mlindner I don't get it. If you have a engine fire isn... Mar 3 2024, 04:22 PM
ClayPerrine
I don't get it. If you have a engine fire isn... Mar 3 2024, 08:32 PM
930cabman Several years ago I was in the market for a 355, m... Mar 3 2024, 05:12 PM
davehg I’m with Team Firewall Access bay!!... Mar 3 2024, 06:17 PM
mlindner Wow, nice Dave. Mar 3 2024, 06:21 PM
windforfun Doesn't the firewall consist of two layers wit... Mar 3 2024, 09:08 PM
sixaddict Track car…..all the stuff about what can be done... Mar 3 2024, 09:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:17 PM |
