Help me figure out what make with this. |
Mikey914 |
Mar 1 2024, 12:31 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What is it ?
Polytetrafluoroethylene Size - I have a bunch cut at 1.75"x1.75"x2" and some strips at 1.75x1.75 at 36" So I can mill or lathe these to make parts easily. The material is known as PTFE Otherwise know as Teflon The question is what to make with it. My 1st thought was a late shifter bushing at the trans. Some have been made out of Brass, but this would be the best possible material. Then Pedal bushings were another thought, but instead of making a product that once the supply dries up I won't be able to make as the cost would be prohibitive, it needs to be a part that clearly this is the best material. So I put this out to the brain trust - What to make ? Here's some more properties Melting point is about 327 C It's chemically inert It has a VERY low coefficient of of friction - nothing will stick to it. It is flexible under a wide temperature range even very cold What to make? Attached thumbnail(s) |
sportlicherFahrer |
Mar 1 2024, 01:57 PM
Nothing to see here. Group: Members Posts: 1,084 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Rear lid torsion spring rollers?
Lo-Fi Version | Time is now: 28th May 2024 - 06:10 PM |
