aha!!!, finally found my electical problem!!! |
jr91472 |
Jan 27 2005, 12:10 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
After much frustration, (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) I finally found the source of my flaky electrical problem.....the socket for one of my round relays (on the fuse panel).
so now the question: has anyone ever found a way to cut into/open up and fix? My problem is the wiring inside the socket. A new socket goes for $30 new (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) once again, these are the rubber sockets the push into and sit on the fuse panel. Any ideas? |
DJsRepS |
Jan 28 2005, 05:45 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
If its the terminals in the sockets they can be cleaned and adjusted. U could use the smooth end of a drill bit as a feeler gauge to see how tight the terminal is and pinch it tighter if needed and if the brass is blackend fill it with fine valve laping compound and use the same smooth end of the bit and give it a good spin. Then use contact cleaner to blow out the compound. Wa La re conditioned socket.
Lo-Fi Version | Time is now: 8th June 2024 - 11:33 AM |
