Quick Run Through on Gun Barrel Black Oxide Finish, Caswell Kit |
914Sixer |
Mar 4 2024, 06:42 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Clean your parts to the max. Soaked in vinegar and the wire brushes to get to the pitted rust. Clean up in soap and water. I wiped down with lacquer thinner, through drying required. Did two dippings, cleaning oxide off with 00 steel wool both times. Rinsed in distilled water (NO Minerals). Hit with steel wool again. Next up, coated parts with penetration oil. Not required BUT I heat up the parts after oil bath. Let oil cook off. Dip again the let stand over night. Good hard coating. Caswell offers protective coating but I like LPS3. Just a quick run though.
Attached image(s) |
jmargush |
Mar 4 2024, 09:14 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
How do you go about heating them? And how hot do you have to get them?
Lo-Fi Version | Time is now: 31st May 2024 - 05:32 PM |
