Quick Run Through on Gun Barrel Black Oxide Finish, Caswell Kit |
914Sixer |
Mar 4 2024, 06:42 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Clean your parts to the max. Soaked in vinegar and the wire brushes to get to the pitted rust. Clean up in soap and water. I wiped down with lacquer thinner, through drying required. Did two dippings, cleaning oxide off with 00 steel wool both times. Rinsed in distilled water (NO Minerals). Hit with steel wool again. Next up, coated parts with penetration oil. Not required BUT I heat up the parts after oil bath. Let oil cook off. Dip again the let stand over night. Good hard coating. Caswell offers protective coating but I like LPS3. Just a quick run though.
Attached image(s) |
gereed75 |
Mar 6 2024, 07:48 AM
Senior Member Group: Members Posts: 1,249 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
That black coating looks great. There are a great many variations on what are termed “black oxide”. See attached
https://finishingandcoating.com/index.php/c...-oxide-coatings Not sure where this particular treatment falls. Other than a decorative effect, it comes down to how rust resistant it is. The standard is testing in a salt spray cabinet That is a whole nother subject of study. The manufacturer of the process usually tests and publishes the results for comparison to other treatments. |
Lo-Fi Version | Time is now: 31st May 2024 - 05:21 PM |
