| vjb206 |
Feb 26 2024, 03:52 PM
Newbie ![]() Group: Members Posts: 32 Joined: 23-December 19 From: New Jersey Member No.: 23,760 Region Association: North East States |
Hey folks! I have the bottom-end of my 2270 assembled and spinning freely. Thanks to all who helped me get to this point!
(IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1708984357.1.gif) To quickly recap: I bought the 2257 kit from AA Pistons (78mm stroke, 5.158" rods, etc.). And when I threw a P&C on for a test-fit last weekend, I immediately noticed the piston sitting proud of the deck height at TDC (negative deck) by about 2mm. (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1708984358.2.gif) Before I overreact, or buy the wrong stuff, I thought I'd ping the community...
Once I figure out whether or not this is normal (I.E. verifying that I don't have to backtrack), I'll get into the CR questions (just waiting on clear plastic from Amazon so that I can measure my CC volume this weekend) (IMG:style_emoticons/default/biggrin.gif) Thanks! |
| Jack Standz |
Mar 6 2024, 10:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 884 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Did some measurements this weekend! (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1709694116.1.gif) My combustion chambers are 60ccs. Measured with fluid as well as called the manufacturer. Double confirmed. (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1709694117.2.gif) Deck height is -0.090. Got that with a dial indicator. @cgnj LMK if this is in your range if you recall... @VaccaRabite great to know re: CR range (and thank you for the details, really) So here's what I'm thinking, would love opinions... • Base shim of 0.090 • Copper head shim of 0.08 That'll get an 8.6 CR ...a 0.060 copper shim would have gotten me to an 8.9CR. I would have run with that prior to reading this thread, but maybe not? You need a base shim of 0.135 and NO fire ring (Head shim) at all to achieve .045 deck height. This is for forged pistons. Base shim of 0.130 for cast stuff. Few use a head shim (fire ring) today due to what Superhawk referred too. If you create a deck height clearance LARGER than .060 you eliminate the quench action which VASTLY increases the tendency to detonate and reduces your compression ratio. Bad in two ways... Less power AND an increased requirement for higher octane fuel. Might want to check the deck height for all cylinders, don't assume they're the same. In addition, you might want to skip the copper head gasket, unless you're racing the car and will re-torque the heads regularly. And using your numbers, you're aiming for zero deck height? If you use a head gasket and zero deck height and you've measured even a little off (again, check the deck heightfor all cylinders), you might end up hitting the piston crown on the head gasket, if it encroaches into the cylinder. Might get away with it, might not. Better to figure it out now before the mock-up. No matter what, plan to mock things up a bunch of times before the final assembly. |
| vjb206 |
Mar 7 2024, 03:16 PM
If I'm 90 under and get a 90 shim I'll be at 0. Then the head gasket = my deck height. based on the thread above, I might not want to go that route in the end (still doing some reading per @superhawk's recco).
Can / should multiple cyl base shims be stacked to achieve desired deck height (rather than doing a cyl shim + head gasket)? Did some measurements this weekend! (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1709694116.1.gif) My combustion chambers are 60ccs. Measured with fluid as well as called the manufacturer. Double confirmed. (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1709694117.2.gif) Deck height is -0.090. Got that with a dial indicator. @cgnj LMK if this is in your range if you recall... @VaccaRabite great to know re: CR range (and thank you for the details, really) So here's what I'm thinking, would love opinions... • Base shim of 0.090 • Copper head shim of 0.08 That'll get an 8.6 CR ...a 0.060 copper shim would have gotten me to an 8.9CR. I would have run with that prior to reading this thread, but maybe not? You need a base shim of 0.135 and NO fire ring (Head shim) at all to achieve .045 deck height. This is for forged pistons. Base shim of 0.130 for cast stuff. Few use a head shim (fire ring) today due to what Superhawk referred too. If you create a deck height clearance LARGER than .060 you eliminate the quench action which VASTLY increases the tendency to detonate and reduces your compression ratio. Bad in two ways... Less power AND an increased requirement for higher octane fuel. Might want to check the deck height for all cylinders, don't assume they're the same. In addition, you might want to skip the copper head gasket, unless you're racing the car and will re-torque the heads regularly. And using your numbers, you're aiming for zero deck height? If you use a head gasket and zero deck height and you've measured even a little off (again, check the deck heightfor all cylinders), you might end up hitting the piston crown on the head gasket, if it encroaches into the cylinder. Might get away with it, might not. Better to figure it out now before the mock-up. No matter what, plan to mock things up a bunch of times before the final assembly. |
vjb206 2270 Deck Height and CR Feb 26 2024, 03:52 PM
Jack Standz 1. It's all in the combination, what pin heig... Feb 26 2024, 08:23 PM
r_towle Did you buy the long liners?
I’m guessing those ... Feb 26 2024, 08:32 PM
Jack Standz Strokers are a lot of fun but also a lot more work... Feb 26 2024, 08:38 PM
Krieger Why don't you call AA and see what they have t... Feb 27 2024, 12:16 AM
VaccaRabite You are asking the wrong question.
Stop everything... Feb 27 2024, 06:54 AM
Montreal914 Read!
Here, on Shoptalkforums, other places…... Feb 27 2024, 11:30 AM
cgnj @vjb206
That looks like my motor did. It is curr... Feb 27 2024, 12:11 PM
MikeK You can shim the cylinder base, use a copper gaske... Feb 27 2024, 12:16 PM
Jack Standz
You can shim the cylinder base, use a copper gask... Feb 27 2024, 01:03 PM
MikeK
You can shim the cylinder base, use a copper gas... Feb 27 2024, 03:35 PM
vjb206 @MikeK great idea! Don't want any scoring... Feb 27 2024, 01:02 PM
VaccaRabite
[b]@[url=http://www.914world.com/bbs2/index.php?... Feb 29 2024, 07:08 AM
Jack Standz There's more to the compression calculation an... Feb 27 2024, 01:14 PM
cgnj @vjb206
I lied somewhere. I said my chamber volum... Feb 27 2024, 04:31 PM
r_towle You need to swap the short cylinders with the long... Feb 27 2024, 06:09 PM
densible1 You'll need to shim bottom of cylinder to achi... Feb 27 2024, 06:23 PM
technicalninja
[b]@[url=http://www.914world.com/bbs2/index.php... Feb 29 2024, 09:39 AM
Geezer914 Almost 1/4" of shims, isn't that a lot? ... Feb 29 2024, 11:26 AM
Jack Standz +1
Yes, agree with post #18 from the ninja above.... Feb 29 2024, 11:42 AM
technicalninja I'm planning on re-using the original Mahle cy... Feb 29 2024, 01:10 PM
vjb206 Did some measurements this weekend!
http://ww... Mar 5 2024, 09:01 PM
Superhawk996 Have you fully researched the use of head gaskets?... Mar 5 2024, 11:03 PM
vjb206
Have you fully researched the use of head gaskets... Mar 6 2024, 08:30 AM
930cabman
Have you fully researched the use of head gaskets... Mar 6 2024, 10:09 AM
technicalninja
[img]htt... Mar 6 2024, 10:00 AM
technicalninja I missed a critical point!
Check deck height ... Mar 6 2024, 10:38 AM
Montreal914 Detail in the grand scheme of things in the curren... Mar 6 2024, 03:09 PM
r_towle I think you need the longer cylinders from AA. Mar 6 2024, 05:49 PM
Superhawk996
Can / should multiple cyl base shims be stacked ... Mar 7 2024, 06:58 PM
vjb206 Just going to do some more reading before pulling ... Mar 7 2024, 09:16 PM
Jack Standz
... Mar 6 2024, 10:35 PM
crash914 Also don't forget:
Pushrods will not be stock.... Mar 7 2024, 12:22 PM
vjb206 Definitely planning on getting deep into the valve... Mar 7 2024, 03:13 PM
930cabman My vote goes to NO head gasket Mar 7 2024, 03:24 PM
technicalninja Proper quench distance is far more important than ... Mar 7 2024, 10:44 PM
vjb206
Proper quench distance is far more important than... Mar 18 2024, 06:40 PM
cgnj @vjb206
I used a .140 shim. No head gasket. I la... Mar 7 2024, 11:31 PM
vjb206
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 8 2024, 04:11 PM
Jack Standz
Proper quench distance is far more important than... Mar 8 2024, 02:27 AM
VaccaRabite I'd say that if you got 60cc measuring with yo... Mar 8 2024, 12:25 PM
vjb206 I honestly never thought about the pushrod tube le... Mar 8 2024, 04:11 PM
GBX0073 Rubber bands were mentioned found this picture to ... Mar 10 2024, 12:14 AM
vjb206
Rubber bands were mentioned found this picture to... Mar 18 2024, 06:35 PM
technicalninja
[quote name='cgnj' post='3132716' date='Mar 8 202... Mar 10 2024, 12:26 PM
vjb206
[quote name='cgnj' post='3132716' date='Mar 8 20... Mar 18 2024, 06:36 PM
vjb206 Just to close the loop here, I ordered a few shims... Mar 19 2024, 08:18 AM
technicalninja I'd run 9.5-10 on that cam.
It's a good s... Mar 19 2024, 08:46 AM
technicalninja Watch for evidence of exhaust back pressure if you... Mar 19 2024, 09:31 AM
burton73 Here is a picture of Marks 2270 RAT built 2005 Eng... Mar 19 2024, 10:37 AM
cgnj @vjb206 Based on your measurements, I think your ... Mar 19 2024, 11:02 AM
burton73 Mark to show shim on the RAT rebuild 2270
Bob B
Mar 19 2024, 11:58 AM
technicalninja OOOHHHH!
Pretty pictures!
Thanks Bob!
... Mar 19 2024, 01:04 PM
Jack Standz Yes, noticed that too. We run phenolic spacers w... Mar 19 2024, 01:25 PM
cgnj I cut my own gaskets. CSP linkage threaded rods to... Mar 19 2024, 02:38 PM
burton73 The picture of intake port is from the moment of t... Mar 19 2024, 03:15 PM
VaccaRabite
The Windage tray modification was a RAT deal in... Mar 20 2024, 05:22 AM
technicalninja When I'm "finished" with port matchi... Mar 19 2024, 05:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th July 2026 - 11:21 PM |
