914-6 throttle rod ….new |
sixaddict |
Mar 7 2024, 08:03 AM
Senior Member Group: Members Posts: 804 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
nditiz1 |
Mar 10 2024, 01:49 PM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I'm not sure I follow. How does the original setup prevent the carbs from sticking? If the carbs are stuck open with either application the pedal will just stay on the floor. The only spring tension is that on the throttles and the shafts.
mate914 |
Mar 10 2024, 07:30 PM
Matt Group: Members Posts: 753 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
I'm not sure I follow. How does the original setup prevent the carbs from sticking? If the carbs are stuck open with either application the pedal will just stay on the floor. The only spring tension is that on the throttles and the shafts. Your right I'm wrong. I was thinking hoop in $100 coat hander would fix this. Then I tried it. Matt |
Lo-Fi Version | Time is now: 31st May 2024 - 09:49 PM |
