| DC_neun_vierzehn |
Mar 14 2024, 09:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
From day one when I bought my 914 a couple of years ago, when I turned the wipers on, they would park wherever they were on the windshield when I turned the wiper switch to the off position (they would NOT go back to the normal park position at 9:00).
Thus, I had to keep turning the switch on and off until I got them where they should park at the bottom of the windshield at 9:00. I thought replacing the wiper switch would do the trick. I installed a NOS SWF wiper switch and now the wipers go to a park position after turning the switch off, but that park position is at about 1:00. I tried removing the wiper arms and adjusting them to see if I could solve the problem, but no dice. With the wiper arms removed, and the wiper switch in the off position, I should be able to install the wiper arms at the 9:00 position and when I turn the switch on they should operate properly. But when I do that and turn the switch on, they go down onto the hood. In order to avoid the wipers from going onto the hood I have install them at the 1:00 position and when I turn the switch on they clean the whole windshield but park at 1:00 when the switch is in the off position. What the heck is going on here? It's almost like the PO installed the wiper motor backwards. Is that even possible? |
| Root_Werks |
Mar 14 2024, 11:07 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,845 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I thought there was something that controlled the park position. I know if I mist my wipers, they park up about an inch too high. If they are running and turned off, they park correctly. Sort of annoying.
DC_neun_vierzehn Windshield wipers parking in middle of windshield WTH?! Mar 14 2024, 09:44 AM
mrholland2
From day one when I bought my 914 a couple of yea... Mar 14 2024, 10:34 AM
Superhawk996 Controlled by a rotating, cam shaped switch in the... Mar 14 2024, 11:26 AM
ClayPerrine The arm that drives the wipers is installed in the... Mar 14 2024, 12:36 PM
DC_neun_vierzehn
The arm that drives the wipers is installed in th... Mar 14 2024, 01:47 PM
ClayPerrine
The arm that drives the wipers is installed in t... Mar 14 2024, 02:48 PM
914_teener
[quote name='DC_neun_vierzehn' post='3133758' dat... Mar 14 2024, 02:51 PM
914_teener
The arm that drives the wipers is installed in th... Mar 14 2024, 02:45 PM
bkrantz
The arm that drives the wipers is installed in th... Mar 14 2024, 07:55 PM
DC_neun_vierzehn
The arm that drives the wipers is installed in th... Jun 20 2024, 11:29 AM
ClayPerrine
[quote name='ClayPerrine' post='3133745' date='Ma... Jun 20 2024, 01:23 PM
DC_neun_vierzehn
[quote name='ClayPerrine' post='3133745' date='M... Jun 20 2024, 01:25 PM
rgalla9146 :agree: with Clay
If you can get a long 10mm ... Mar 14 2024, 07:40 PM
Dave_Darling He's not talking about the wiper arms. He... Mar 14 2024, 08:19 PM
fixer34 As noted, that is also what you do if you want to ... Mar 14 2024, 08:26 PM
DC_neun_vierzehn Ok. Finally getting around to addressing my wipers... Jun 19 2024, 10:32 AM
DC_neun_vierzehn I’m guessing I have to get it from inside the ca... Jun 19 2024, 10:47 AM
Olympic 914 http://www.914world.com/bbs2/index.php?sho...=3049... Jun 19 2024, 11:05 AM
DC_neun_vierzehn
http://www.914world.com/bbs2/index.php?sho...=304... Jun 19 2024, 12:36 PM
DC_neun_vierzehn This video helped me figure it out (from around th... Jun 19 2024, 02:57 PM
DC_neun_vierzehn Here is the access point (speedo removed and looki... Jun 19 2024, 04:10 PM
DC_neun_vierzehn Last question ...
Before I attempt to re-install... Jun 22 2024, 08:34 AM
DC_neun_vierzehn
Last question ...
Before I attempt to re-instal... Jun 23 2024, 08:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2025 - 01:53 PM |
