> Windshield wipers parking in middle of windshield WTH?!
DC_neun_vierzehn
post Mar 14 2024, 09:44 AM
From day one when I bought my 914 a couple of years ago, when I turned the wipers on, they would park wherever they were on the windshield when I turned the wiper switch to the off position (they would NOT go back to the normal park position at 9:00).
Thus, I had to keep turning the switch on and off until I got them where they should park at the bottom of the windshield at 9:00.
I thought replacing the wiper switch would do the trick. I installed a NOS SWF wiper switch and now the wipers go to a park position after turning the switch off, but that park position is at about 1:00. I tried removing the wiper arms and adjusting them to see if I could solve the problem, but no dice.
With the wiper arms removed, and the wiper switch in the off position, I should be able to install the wiper arms at the 9:00 position and when I turn the switch on they should operate properly.
But when I do that and turn the switch on, they go down onto the hood. In order to avoid the wipers from going onto the hood I have install them at the 1:00 position and when I turn the switch on they clean the whole windshield but park at 1:00 when the switch is in the off position.
What the heck is going on here?
It's almost like the PO installed the wiper motor backwards. Is that even possible?
ClayPerrine
post Mar 14 2024, 12:36 PM
The arm that drives the wipers is installed in the wrong position on the wiper motor.
1. Take the arm off the wiper motor shaft.
2. Turn the wipers on and then off so the motor goes to the park position.
3. Position the arm so that the wipers are in the correct park position on the windshield.
4. (IMG:style_emoticons/default/beer3.gif)
914_teener
post Mar 14 2024, 02:45 PM
QUOTE(ClayPerrine @ Mar 14 2024, 10:36 AM) *
Think Clay is right...Occum's Razor thing....but maybe also the cam contacts are worn or gunky. Try indexing them first as Clay says.
DC_neun_vierzehn   Windshield wipers parking in middle of windshield WTH?!   Mar 14 2024, 09:44 AM
mrholland2   From day one when I bought my 914 a couple of yea...   Mar 14 2024, 10:34 AM
Root_Werks   I thought there was something that controlled the ...   Mar 14 2024, 11:07 AM
Superhawk996   Controlled by a rotating, cam shaped switch in the...   Mar 14 2024, 11:26 AM
ClayPerrine   The arm that drives the wipers is installed in the...   Mar 14 2024, 12:36 PM
DC_neun_vierzehn   The arm that drives the wipers is installed in th...   Mar 14 2024, 01:47 PM
ClayPerrine   The arm that drives the wipers is installed in t...   Mar 14 2024, 02:48 PM
914_teener   [quote name='DC_neun_vierzehn' post='3133758' dat...   Mar 14 2024, 02:51 PM
914_teener   The arm that drives the wipers is installed in th...   Mar 14 2024, 02:45 PM
bkrantz   The arm that drives the wipers is installed in th...   Mar 14 2024, 07:55 PM
DC_neun_vierzehn   The arm that drives the wipers is installed in th...   Jun 20 2024, 11:29 AM
ClayPerrine   [quote name='ClayPerrine' post='3133745' date='Ma...   Jun 20 2024, 01:23 PM
DC_neun_vierzehn   [quote name='ClayPerrine' post='3133745' date='M...   Jun 20 2024, 01:25 PM
rgalla9146   :agree: with Clay If you can get a long 10mm ...   Mar 14 2024, 07:40 PM
Dave_Darling   He's not talking about the wiper arms. He...   Mar 14 2024, 08:19 PM
fixer34   As noted, that is also what you do if you want to ...   Mar 14 2024, 08:26 PM
DC_neun_vierzehn   Ok. Finally getting around to addressing my wipers...   Jun 19 2024, 10:32 AM
DC_neun_vierzehn   I’m guessing I have to get it from inside the ca...   Jun 19 2024, 10:47 AM
Olympic 914   http://www.914world.com/bbs2/index.php?sho...=3049...   Jun 19 2024, 11:05 AM
DC_neun_vierzehn   http://www.914world.com/bbs2/index.php?sho...=304...   Jun 19 2024, 12:36 PM
DC_neun_vierzehn   This video helped me figure it out (from around th...   Jun 19 2024, 02:57 PM
DC_neun_vierzehn   Here is the access point (speedo removed and looki...   Jun 19 2024, 04:10 PM
DC_neun_vierzehn   Last question ... Before I attempt to re-install...   Jun 22 2024, 08:34 AM
DC_neun_vierzehn   Last question ... Before I attempt to re-instal...   Jun 23 2024, 08:07 AM
- Lo-Fi Version Time is now: 15th November 2025 - 01:55 PM
