Fun with troubleshooting leanness (and 5th gear cruising temps) |
emerygt350 |
Mar 15 2024, 03:37 PM
Advanced Member Group: Members Posts: 2,138 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
So I have been playing with adding resistance to the cht to bump my mixture. Messing with the mps was not getting me to where I wanted to be I wanted something a little more global. Anyway, bought a 10 dollar Bluetooth relay. Set it up so one channel was clean the other had 50ohms resistance in it. As I am driving I can switch back and forth and watch the results on the cht and AFR. 50 is really working well (this is all in addition to my 250ohm found on 73s). Now I have added another 20 ohms to the alternate so the relay will switch between 50 and 70. It ain't pretty but it's only for troubleshooting.
emerygt350 |
Mar 15 2024, 06:51 PM
That actually looks kosher. Just a pot adding resistance to the cht circuit.
On the timing front I have found in my 2056 with stock cam etc that 8 degrees advance was all I could add temp wise, advance disconnected. The engine wants 9. It just sounds, responds, everything better at 9 maybe even 10. Temps wouldn't allow it. I have the advance disconnected. Sadly I think the 123 dizzy doesn't have the finesse of the original retard advance analog fight the original dizzy had. I think it probably throws too much in and it makes the lean fight harder. So I am waiting till I feel good with my mix, then will add it back in later to see what effect it has. I may just end up with a rich switch for long climbs. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:47 AM |
