Fun with troubleshooting leanness (and 5th gear cruising temps) |
emerygt350 |
Mar 15 2024, 03:37 PM
Advanced Member Group: Members Posts: 2,144 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
So I have been playing with adding resistance to the cht to bump my mixture. Messing with the mps was not getting me to where I wanted to be I wanted something a little more global. Anyway, bought a 10 dollar Bluetooth relay. Set it up so one channel was clean the other had 50ohms resistance in it. As I am driving I can switch back and forth and watch the results on the cht and AFR. 50 is really working well (this is all in addition to my 250ohm found on 73s). Now I have added another 20 ohms to the alternate so the relay will switch between 50 and 70. It ain't pretty but it's only for troubleshooting.
r_towle |
Mar 17 2024, 06:57 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I took my personal engine to 2.6, back to carbs and a better camshaft.
I’m changing to ITB and EFI, with fully tunable settings….because it’s time |
emerygt350 |
Mar 18 2024, 06:10 AM
I took my personal engine to 2.6, back to carbs and a better camshaft. I’m changing to ITB and EFI, with fully tunable settings….because it’s time Yeah, since I just did a quick top end build the cam wasn't an option. When I go deeper next time I will definitely upgrade the cam, that is probably what is causing most of my problems at cruise. I have heard they run hotter than they should due to the exhaust timing I think. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:39 PM |
