| vjb206 |
Feb 26 2024, 03:52 PM
Newbie ![]() Group: Members Posts: 32 Joined: 23-December 19 From: New Jersey Member No.: 23,760 Region Association: North East States |
Hey folks! I have the bottom-end of my 2270 assembled and spinning freely. Thanks to all who helped me get to this point!
(IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1708984357.1.gif) To quickly recap: I bought the 2257 kit from AA Pistons (78mm stroke, 5.158" rods, etc.). And when I threw a P&C on for a test-fit last weekend, I immediately noticed the piston sitting proud of the deck height at TDC (negative deck) by about 2mm. (IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1708984358.2.gif) Before I overreact, or buy the wrong stuff, I thought I'd ping the community...
Once I figure out whether or not this is normal (I.E. verifying that I don't have to backtrack), I'll get into the CR questions (just waiting on clear plastic from Amazon so that I can measure my CC volume this weekend) (IMG:style_emoticons/default/biggrin.gif) Thanks! |
| technicalninja |
Mar 19 2024, 01:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
OOOHHHH!
Pretty pictures! Thanks Bob! What's up with the pic of the intake port? It looks like the gasket overhangs both the head below and the intake above (from the print in the gasket) |
vjb206 2270 Deck Height and CR Feb 26 2024, 03:52 PM
Jack Standz 1. It's all in the combination, what pin heig... Feb 26 2024, 08:23 PM
r_towle Did you buy the long liners?
I’m guessing those ... Feb 26 2024, 08:32 PM
Jack Standz Strokers are a lot of fun but also a lot more work... Feb 26 2024, 08:38 PM
Krieger Why don't you call AA and see what they have t... Feb 27 2024, 12:16 AM
VaccaRabite You are asking the wrong question.
Stop everything... Feb 27 2024, 06:54 AM
Montreal914 Read!
Here, on Shoptalkforums, other places…... Feb 27 2024, 11:30 AM
cgnj @vjb206
That looks like my motor did. It is curr... Feb 27 2024, 12:11 PM
MikeK You can shim the cylinder base, use a copper gaske... Feb 27 2024, 12:16 PM
Jack Standz
You can shim the cylinder base, use a copper gask... Feb 27 2024, 01:03 PM
MikeK
You can shim the cylinder base, use a copper gas... Feb 27 2024, 03:35 PM
vjb206 @MikeK great idea! Don't want any scoring... Feb 27 2024, 01:02 PM
VaccaRabite
[b]@[url=http://www.914world.com/bbs2/index.php?... Feb 29 2024, 07:08 AM
Jack Standz There's more to the compression calculation an... Feb 27 2024, 01:14 PM
cgnj @vjb206
I lied somewhere. I said my chamber volum... Feb 27 2024, 04:31 PM
r_towle You need to swap the short cylinders with the long... Feb 27 2024, 06:09 PM
densible1 You'll need to shim bottom of cylinder to achi... Feb 27 2024, 06:23 PM
technicalninja
[b]@[url=http://www.914world.com/bbs2/index.php... Feb 29 2024, 09:39 AM
Geezer914 Almost 1/4" of shims, isn't that a lot? ... Feb 29 2024, 11:26 AM
Jack Standz +1
Yes, agree with post #18 from the ninja above.... Feb 29 2024, 11:42 AM
technicalninja I'm planning on re-using the original Mahle cy... Feb 29 2024, 01:10 PM
vjb206 Did some measurements this weekend!
http://ww... Mar 5 2024, 09:01 PM
Superhawk996 Have you fully researched the use of head gaskets?... Mar 5 2024, 11:03 PM
vjb206
Have you fully researched the use of head gaskets... Mar 6 2024, 08:30 AM
930cabman
Have you fully researched the use of head gaskets... Mar 6 2024, 10:09 AM
technicalninja
[img]htt... Mar 6 2024, 10:00 AM
technicalninja I missed a critical point!
Check deck height ... Mar 6 2024, 10:38 AM
Montreal914 Detail in the grand scheme of things in the curren... Mar 6 2024, 03:09 PM
r_towle I think you need the longer cylinders from AA. Mar 6 2024, 05:49 PM
Jack Standz
[img]ht... Mar 6 2024, 10:27 PM
vjb206 If I'm 90 under and get a 90 shim I'll be ... Mar 7 2024, 03:16 PM
Superhawk996
Can / should multiple cyl base shims be stacked ... Mar 7 2024, 06:58 PM
vjb206 Just going to do some more reading before pulling ... Mar 7 2024, 09:16 PM
Jack Standz
... Mar 6 2024, 10:35 PM
crash914 Also don't forget:
Pushrods will not be stock.... Mar 7 2024, 12:22 PM
vjb206 Definitely planning on getting deep into the valve... Mar 7 2024, 03:13 PM
930cabman My vote goes to NO head gasket Mar 7 2024, 03:24 PM
technicalninja Proper quench distance is far more important than ... Mar 7 2024, 10:44 PM
vjb206
Proper quench distance is far more important than... Mar 18 2024, 06:40 PM
cgnj @vjb206
I used a .140 shim. No head gasket. I la... Mar 7 2024, 11:31 PM
vjb206
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 8 2024, 04:11 PM
Jack Standz
Proper quench distance is far more important than... Mar 8 2024, 02:27 AM
VaccaRabite I'd say that if you got 60cc measuring with yo... Mar 8 2024, 12:25 PM
vjb206 I honestly never thought about the pushrod tube le... Mar 8 2024, 04:11 PM
GBX0073 Rubber bands were mentioned found this picture to ... Mar 10 2024, 12:14 AM
vjb206
Rubber bands were mentioned found this picture to... Mar 18 2024, 06:35 PM
technicalninja
[quote name='cgnj' post='3132716' date='Mar 8 202... Mar 10 2024, 12:26 PM
vjb206
[quote name='cgnj' post='3132716' date='Mar 8 20... Mar 18 2024, 06:36 PM
vjb206 Just to close the loop here, I ordered a few shims... Mar 19 2024, 08:18 AM
technicalninja I'd run 9.5-10 on that cam.
It's a good s... Mar 19 2024, 08:46 AM
technicalninja Watch for evidence of exhaust back pressure if you... Mar 19 2024, 09:31 AM
burton73 Here is a picture of Marks 2270 RAT built 2005 Eng... Mar 19 2024, 10:37 AM
cgnj @vjb206 Based on your measurements, I think your ... Mar 19 2024, 11:02 AM
burton73 Mark to show shim on the RAT rebuild 2270
Bob B
Mar 19 2024, 11:58 AM
Jack Standz Yes, noticed that too. We run phenolic spacers w... Mar 19 2024, 01:25 PM
cgnj I cut my own gaskets. CSP linkage threaded rods to... Mar 19 2024, 02:38 PM
burton73 The picture of intake port is from the moment of t... Mar 19 2024, 03:15 PM
VaccaRabite
The Windage tray modification was a RAT deal in... Mar 20 2024, 05:22 AM
technicalninja When I'm "finished" with port matchi... Mar 19 2024, 05:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th July 2026 - 11:11 PM |
