jandro62 |
Member ![]() ![]() Group: Members Posts: 104 Joined: 4-June 04 From: Texas Member No.: 2,156 ![]() |
So I popped the access panels off the tunnel, and despite the tunnel looking solid from the top, and solid from the underside of the car, there is soooo much rust in there. I had a field day with the magnetic pickup removing all sorts of crap. I even found a walnut shell, don't know how that got in there. Its enough rust that it worries me. Is this tunnel thing separate from the floorboards? How would I go about replacing it? Hell, do I try and plasma torch one side off of it to get at the rust and try and tack it back together?
Thanks, Alex |
jimtab |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California ![]() |
You don't have to cut open the tunnel to replace the lines they can be removed and re fitted thru the openings in the back where they connect to the rubber lines, BUT as I found out after I demoed them, the hard lines are almost never the leaking problem, it's usually the rubber hoses and connections. Just my .02 |
Lo-Fi Version | Time is now: 11th July 2025 - 04:25 PM |
