Runs for a Second and Dies, 1.8fi Starts, Runs for a Second, then Dies. |
CYCPYT |
Mar 25 2024, 07:42 AM
Newbie Group: Members Posts: 16 Joined: 9-February 23 From: Culleoka Member No.: 27,149 Region Association: NineFourteenerVille |
Any advice on a forum article I should go to, or advice on how to troubleshoot this would be appreciated.
I have replaced the fuel filter and fuel pump, as I originally thought it was a fuel issue. Now I am not sure. Thank you! |
rfinegan |
Mar 25 2024, 10:23 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I had a similar symptom on my 2.0 DJet( know is different ) but crank start and die....If I continue to pump the pedal in different location of open while staring and running the engine wold continue to run "like pumping and an accelerator pump” the root cause end up being the CHT sensor on/ @ 3 cly. I replaced the sensor and starts and runs great after the change.
GOOD place to start looking... |
CYCPYT |
Mar 25 2024, 04:33 PM
I had a similar symptom on my 2.0 DJet( know is different ) but crank start and die....If I continue to pump the pedal in different location of open while staring and running the engine wold continue to run "like pumping and an accelerator pump” the root cause end up being the CHT sensor on/ @ 3 cly. I replaced the sensor and starts and runs great after the change. GOOD place to start looking... Thank you, I will put this on the list of things to check. |
Lo-Fi Version | Time is now: 29th May 2024 - 12:24 AM |
