Dry sump leakdown prevention? |
gnomefabtech |
Mar 25 2024, 11:02 AM
Member Group: Members Posts: 111 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Hello!
So I'm running a dry-sump system on my 'teen and it's all great except if the car sits for a few days the oil in the tank slowly fills the motor. This wouldn't be a big deal except it floods the turbo and then there's smoke. So much smoke. Does anyone have experience using a low cracking pressure check valve to hold the oil in the tank until the car is running? I see a selection of these on McMaster but I'm understandably nervous about restricting the flow into the engine from the tank. It's a -12 an line coming out of the tank. What did Porsche do about this on their dry-sump systems? I'm running a Hayabusa engine (build thread to follow) so it's a pretty unconventional build but the oiling thing is common to all dry-sumps. Thanks for answering these questions. |
fixer34 |
Mar 25 2024, 09:54 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Rothsport. Is your engine worth more than $300?? Mine is on a factory -6, there are 911 versions also. This is NOT your run of the mill 'check valve'. Too little sealing pressure and you might as well not bother; too much and you get oil starvation on startup followed shortly by spun bearings.
Some things in life you can go cheap on; this isn't one of them. |
Lo-Fi Version | Time is now: 31st May 2024 - 07:00 PM |
