5 lug rear rotors |
5 lug rear rotors |
jmargush |
Mar 25 2024, 04:18 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
Are the 5 lug rear rotors supposed to use the 2 small screws to mount them to the hub or does the wheel just hold them to the hub?
Attached thumbnail(s) |
willieg |
Mar 26 2024, 05:40 PM
Member Group: Members Posts: 132 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California |
I had the same problem with the screw holes in the rotor not lining up with the tapped screw holes in the hub. I drilled and tapped the hubs, instead of just drilling new holes in the rotors. I figured I would need new rotors before new hubs.
jmargush |
Mar 26 2024, 08:22 PM
I had the same problem with the screw holes in the rotor not lining up with the tapped screw holes in the hub. I drilled and tapped the hubs, instead of just drilling new holes in the rotors. I figured I would need new rotors before new hubs. Good to know someone else had the same problem |
Lo-Fi Version | Time is now: 7th June 2024 - 09:44 PM |
