Runs for a Second and Dies, 1.8fi Starts, Runs for a Second, then Dies. |
CYCPYT |
Mar 25 2024, 07:42 AM
Newbie Group: Members Posts: 16 Joined: 9-February 23 From: Culleoka Member No.: 27,149 Region Association: NineFourteenerVille |
Any advice on a forum article I should go to, or advice on how to troubleshoot this would be appreciated.
I have replaced the fuel filter and fuel pump, as I originally thought it was a fuel issue. Now I am not sure. Thank you! |
brant |
Mar 27 2024, 09:28 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the 4 wire loom that plugs into the distributor points
is a very fragile connection that often fails or breaks first due to heat I'd check that connector... I once used an ohm meter to check all 27? wires from the ECU brant |
Lo-Fi Version | Time is now: 29th May 2024 - 01:49 AM |
