MPS Differences?, 0280100041 vs 0280100043 |
FlacaProductions |
Mar 27 2024, 05:10 PM
Senior Member Group: Members Posts: 1,598 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Seeing both part numbers seeming used interchangeably between 1.7 and 2.0's.
Was there a year that a changeover was made or? |
914Sixer |
Mar 28 2024, 12:18 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Click to open
Attached thumbnail(s) |
JamesM |
Mar 28 2024, 10:43 PM
Senior Member Group: Members Posts: 1,912 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Click to open That is only a partial list. This page as a far more comprehensive listing of d-jet MPS https://jetronic.org/en/d-jetronic/mps Also if you plan on re-tuning an MPS to a different spec you might not get to far with the information from Brad Anders page. He has correct information however as the MPS themselves are effected by altitude and atmospheric pressure. Adjusting one based on the inductance specs he provides might get you close but as they will vary based on where you are, and just day to day based on air pressure the best way I have found to do it is to basically "clone" the adjustment of a known good sensor on the bench. I used a T'ed vacuum setup and a switch attached to my meter to ensure two sensors are identical across the entire operating range. |
Lo-Fi Version | Time is now: 29th May 2024 - 01:59 AM |
