| RFoulds |
Mar 29 2024, 03:14 PM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 861 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
Finally installing my oil lines and the sandwich adaptor is thicker than my old one I think. Using a Derale oil filter adaptor, model no. 15702. this is making my stock Mahle filter OC28 hang down too far and the engine mount bar is in the way.
Has anyone found a shorter filter to use? |
| RFoulds |
Mar 29 2024, 03:51 PM
looks like that is same size and length. Do you know which sandwich plate you have?
But I think I found the issue. When I had motor rebuilt, we replaced cracked oil filter console. the new one looks to be mounted slightly askew, just enough that the oil filter cannot hang behind the bar, or even start threading on just behind the bar. it is about 6mm too wide. So I may need to adjust the filter console a bit. |
RFoulds need shorter oil filter for sandwich Mar 29 2024, 03:14 PM
Geezer914 I use K&N 2004 oil filters. Mar 29 2024, 03:21 PM
bdstone914 Rfoulds
You need to look for a filter with a 3/4-... Mar 30 2024, 11:24 AM
ClayPerrine The filter for a 1979 924 fits and is physically s... Apr 1 2024, 08:39 AM
TheCabinetmaker
The filter for a 1979 924 fits and is physically ... Apr 9 2026, 05:49 PM
Geezer914 I have a Mocal unit. Apr 1 2024, 10:16 AM
Geezer914 The filter for the 924 is around 5" long so i... Apr 1 2024, 12:58 PM
RFoulds Thanks everyone. Discovered that my issue was tha... Apr 3 2024, 09:37 AM
Alapone
Thanks everyone. Discovered that my issue was th... Apr 15 2024, 09:15 AM
914werke
The filter for the 924 is around 5" long so ... Apr 9 2026, 02:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th April 2026 - 07:05 PM |
